587,818 active members*
2,846 visitors online*
Thread: 1.2020
Results 1 to 14 of 14
    Jun 2012
    393
    1.2020
    I see this version on the web site. Is this the latest. I see that they recommend setting up a new profile.
    Don
    The time has come the woodworker said to speak of many things. 0f routers and Wood , chips and paints and stains and CNC and other things.
    Jun 2015
    943
    Re: 1.2020
    Quote Originally Posted by Gallchobhair View Post
    Don
    I don't see where they recommend setting up new profile?
    I already have version 1.2 installed and they recommend setting up new profile when moving from version 1.0 or 1.1.
    Jun 2012
    393
    Re: 1.2020
    Quote Originally Posted by OlfCNC View Post
    From the website. I am at 1.1027
    Migrating from version 1.0xxx to 1.1xxx, 1.0xxx to 1.2xxx or 1.1xxx to 1.2xxx
    Using an older major-version machine profile with a newer major software version is not recommended, we advice to create a new machine profile with the new major-version release when starting the work with the new software version. Also because there are many differences between the different major-versions of the software we advice to first install the new version into a different folder on the computer keeping the old version alive until the new version will be setup and running.
    35538
    Re: 1.2020
    Looks like this version has added support for an ethernet version of the UC300, and maybe some new breakout boards?
    Looks like one breakout board has 54 inputs and 41 outputs?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Oct 2005
    1145
    Re: 1.2020
    Jun 2014
    777
    Re: 1.2020
    sweet, they added my line number suggestion to edit file
    Oct 2005
    1145
    Re: 1.2020
    The line numbering is a bit different than the normal BUT it does work (;-)
    (;-) TP
    Jun 2014
    777
    Re: 1.2020
    Quote Originally Posted by vmax549 View Post
    (;-) TP
    Yes, to have a goto line tho which is cool. I didn't find the edit was of much help until now, I would mostly want to use it to avoid scrolling through code as much as possible, you could before go into edit code and use find for operation name you were searching for but as it didn't give you a line number it was of no help at all. Now it does im very happy.
    Oct 2005
    1145
    Re: 1.2020
    THE normal would be to have it similar to Mach3 where you can display teh actual line number in teh Gcode window and you can use notepad++ and display the actual line number to teh left of the Gcode. That keeps it simple and easy to use.
    (;-) TP
    Jun 2014
    777
    (;-) TP
    Yeah, does Mach 3 have an edit file function I can't remember. No need for notepad with uccnc new edit file
    Jan 2014
    57
    Re: 1.2020
    Just uploaded the new version and I was pleased to find the new plugin for the wireless XHC-HB04 pendant. Works great without any problems.
    Now I'm waiting for the lathe version and the SAE/Metric buttons. Bob
    Apr 2013
    12
    Re: 1.2020
    Quote Originally Posted by bpratl View Post
    Did you need to do anything other than plug in the USB dongle to get the XHC-HB04 to work?
    thanks,
    Jim
    Jan 2014
    57
    Re: 1.2020
    Quote Originally Posted by bullwinkle223 View Post
    thanks,
    Jim
    Hi Jim, I just selected the plugin, configured and enabled it and it worked.
    Bob
    Apr 2013
    12
    Re: 1.2020
    Excellent. Thanks. I have mine arriving from China today and I'm looking forward to getting it up and running.
    I found reference to the XHC-HB04 and setup of softlimits on the Stepcraft forum. I'll have to look into this too.
    https://www.stepcraft-systems.com/en...ntrol-xhc-hb04
    Regards,
    Jim
  1. Aluminium extrusions 2020 2040
    By Yaro in forum Want To Buy...Need help!
    Last Post: 08-30-2014, 08:53 AM
  2. Robofil 2020 reference point
    By dzcatic in forum EDM Discussion General Topics
    Last Post: 11-07-2013, 12:35 PM
  3. Rutex 2020 card
    By johnd in forum Servo Drives
    Last Post: 01-18-2008, 01:43 AM
  4. enclosure for 2020 drives
    By najnielkp in forum Servo Drives
    Last Post: 07-06-2006, 05:20 PM
  5. 2020 / 2100 hookup
    Last Post: 10-19-2005, 02:59 AM
