I am working with a 1991 Fanuc Drill Mate t-model 10 with a 0mb control. I am so close to getting this to work I can taste it! I am pressing [edit] [program] [floppy] [read] [01234] [input] [exec]... It should flash LSK after that but I get this 086 alarm! I must be off somewhere with the ladder parameters, the manual says the alarm is when inputing/outputing via reader/puncher interface, the ready signal (DR) of the input /output device is off, what does that mean? I am contecting from the DB25 port located in the front of the panel near the keyboards and crt, it is the only DB25 serial com port I can find on the machine.What must I do to get it to flash LSK and search for incoming data?
