I am trying to actually make a few bucks selling parts with my sherline, so its important to be able to remove as much material as possible as quickly as possible.
I seem to be getting consistently good results with a 3 flute roughing end mill in 6061-T6511. Its a Niagara 75215 roughing end mill, available from mcmaster.
This wasn't my idea, I first saw this endmill (very similar) being used here:
Roughing End Mill | North Branch Reels
At 0.050" doc, 9 ipm, with a full width 1/4" diameter slot, seems to be okay. It makes noise, but it doesn't sound like bad noise. (see video below) That said, I've only been machining for about 3 months.
I can also plunge very quietly (almost no noise at all actually) at 0.3ipm. In the video, it might seem to make alot of noise during the plunge, thats because my spiral lead in move is really jamming the end mill in..didnt fix that in time. But when its a straight plunge at 0.3ipm, its silent.
Also, I've noticed that at 12ipm it sometimes sounds even quieter. Not always, but sometimes. Its not stable enough at 12ipm for me to use it regularly.
YOUTUBE Sherline Aluminum .050" doc, 9ipm, 6061
The video shows me cutting at 9ipm, this isnt a fresh endmill, I've used it to make about 7 similar brackets so its got whatever wear that might cause to it.
The mill is setup with fairly light gib tightness, and backlash around 3 thou.
I'm pretty happy because this lets me make 6061 parts in reasonable amounts of time. The tool path for the pictured part is about an hour with manual tool changes.
Im wondering if an experienced machinist could tell me how I could analyze the machining results at this speed to tell if its really appropriate or not. I guess the finished parts tell the whole story, but I'm wondering if maybe there is more to it than that.
Also, I wonder if I can get the speed up to 12ipm regularly, or even 15ipm? How can we make this faster?
