Im running large programs on a Mori-Seki SV503 and would like to know if there is a way to run programs directly from the memory card.
Thank you,
Larry
Thank you,
Larry
Yes, but the problem you will run into is RS232 will stop working. It's pain in the behind to switch back and forth, the setting for memory card and RS232 is the same page and the setting quite difference.
The best way to learn is trial error.
I don't have the procedure here, but yes you can. SV503 is a Maps control, so I would call the dist. (probably Ellison) they will have a procedure they can fax to you. We used to do it all the time.
