586,161 active members*
3,220 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > Only Y works correct X don't work Z works one direction only
    Jan 2008
    Hi
    I have a mill with 3 axis pro board,(Hobbycnc) the mill worked great 4 years ago after moving and atorage and rebuild - now I only get Y axes to work
    right
    X Axis :
    No movement but it locks up
    I have the 3A steppers on the masjine so the motor setting on the board should be set to 0.42v but if set to maksimum - I only get 0.23v - Both Y and Z axis are set to 0.42v
    The question is - why only 0.23v and is this why X dont move
    The 5v test gives 5.03v
    Z Axis :
    Moves only in one direction does not matter if Mach 3 are told to move up or
    down Z just move up
    Is this becouse of above problem with X or is this something else
    Using mach 3
    EPP printer port
    Mach3 are set pin 3 = x step, 2 = x dir 5 = y step 4= y dir 7 = z step 6 = z dir
    Please help
    Apr 2007
    Hi, I am have the exact same problem, spent many hours trying to figure it out..... ever fix yours?
    Jan 2012
    28
    I have one of these working
    I have a hobby cnc pro board working. I am looking for a schematic for the board.
  1. The engine works but only in one direction
    By Marfon in forum LinuxCNC (formerly EMC2)
    Last Post: 11-29-2008, 08:44 PM
  2. Can someone tell me how this PIC works?
    By KPyro in forum Stepper Motors / Drives
    Last Post: 12-09-2006, 10:48 PM
  3. Another one in the works..
    By CRFultz in forum CNC Wood Router Project Log
    Last Post: 12-23-2004, 08:09 AM
  4. It's done (and it works!)
    By Joe Petro in forum DIY CNC Router Table Machines
    Last Post: 01-09-2004, 08:07 PM
  5. How does G 41, G42 works ?
    By BanglaTech in forum Uncategorised CAM Discussion
    Last Post: 11-04-2003, 06:38 PM
