586,740 active members*
2,689 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Help with 4 axis for FX10 wire Machine
Results 1 to 6 of 6
    Feb 2010
    Help With 4 axis MasterCam And FX10
    can someone tell me why when we make a simple 4 axis program in mastercam with two 1 inch holes three inches apart at a 7.125 dree. angle. It looks good in mastercam but when we run it on the FX10 is turns out eggshaped.
    thanks justin
    Mar 2005
    461
    Try to break both the upper and lower arcs in half so that all arcs are 180° segments... Somehow this gets MC to post the code correctly.
    I've had the same problem with our Fanuc WEDM. It's not the machines or the post processor... Just a MC bug...
    Feb 2010
    I and J's
    Does your machine use incramental programing in uv axis? example short line segments to create an arc? Mitsubishi do not use I's and J's to create arc. I have tried to break the program the circle into four sections and using by branch command, it looks not right on screen so I did not run it. thanks for your help.
    Mar 2005
    461
    Here is what the code would look like on my machine...
    Code:
    O0100
    (FANUC WIRE)
    (NAME -  TEST )
    (D-M-Y  15-02-10  TIME  09:24 )
    G0 G90 G40 G50
    M50
    G77 P1
    G92 X0 Y0 I1. J0.
    M31
    N100 X.35 Y0.
    M37
    S1 D1 G04 X2.
    M15 P11
    M60
    G92 X.35 Y0. I1. J0.
    G41 G1 X.5 U.125
    G3 X-.5 I-.5 U-.125
    X.5 I.5 U.125
    G40 G1 X.35 U0.
    N110 X.35 Y0.
    M38
    S2 D2 G04 X2.
    G41 G1 X.5 U.125
    G3 X-.5 I-.5 U-.125
    X.5 I.5 U.125
    G40 G1 X.35 U0.
    N120 X.35 Y0.
    M38
    S3 D3 G04 X2.
    G41 G1 X.5 U.125
    G3 X-.5 I-.5 U-.125
    X.5 I.5 U.125
    G40 G1 X.35 U0.
    N130 X.35 Y0.
    M38
    S4 D4 G04 X2.
    G41 G1 X.5 U.125
    G3 X-.5 I-.5 U-.125
    X.5 I.5 U.125
    G40 G1 X.35 U0.
    M50
    U0 V0
    N140 G0 X3.35 Y0.
    M37
    M01 (TAB STOP)
    S1 D1 G04 X2.
    M15 P11
    M60
    G92 X3.35 Y0. I1. J0.
    G41 G1 X3.5 U.125
    G3 X2.5 I-.5 U-.125
    X3.5 I.5 U.125
    G40 G1 X3.35 U0.
    N150 X3.35 Y0.
    M38
    S2 D2 G04 X2.
    G41 G1 X3.5 U.125
    G3 X2.5 I-.5 U-.125
    X3.5 I.5 U.125
    G40 G1 X3.35 U0.
    N160 X3.35 Y0.
    M38
    S3 D3 G04 X2.
    G41 G1 X3.5 U.125
    G3 X2.5 I-.5 U-.125
    X3.5 I.5 U.125
    G40 G1 X3.35 U0.
    N170 X3.35 Y0.
    M38
    S4 D4 G04 X2.
    G41 G1 X3.5 U.125
    G3 X2.5 I-.5 U-.125
    X3.5 I.5 U.125
    G40 G1 X3.35 U0.
    M50
    M29
    M15 P0
    M30
    Oct 2010
    Arrow program problems?
    Is the trouble your having have to do with cutting a radius move at an angle and having it turn out conical on a mitsubishi fx10 wire machine?
    May 2013
    Let me get this you are cutting two 1" holes, 3" apart at 7.125 degrees correct. Are those two holes are in a plane that is tilted 7.125 degrees if so you are cutting on the hypotenuse the two holes will be Elliptical. If you view it perpendicular to the plane. Otherwise it will look round, viewed from the 7.125 angle
    When it was cut.
  1. Replies: 15
    Last Post: 06-30-2016, 04:38 PM
  2. Looking for an Epack for Mits. FX10
    By 3dmachinist in forum EDM Discussion General Topics
    Last Post: 08-25-2009, 12:23 PM
  3. SURFCAM 2004 POST FOR MITSUBISHI FX10
    Last Post: 08-19-2009, 11:24 PM
  4. mitsubishi fx10 alarms
    By waldocnc in forum EDM Discussion General Topics
    Last Post: 06-15-2009, 01:26 PM
  5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
