587,035 active members*
3,306 visitors online*
Results 1 to 20 of 34
    Dec 2006
    406
    Bad Hard Drive
    I have a 1997 Bmc 30 with ultimax 3 controls. The hard drive is made by seagate and is 681 mb. I know the drive is shot and needs to be replaced.
    Hurco charges 750.00 for a replacement and 250.00 to reload software. I have all the original disks and the backup disks but am not 100 percent they are good. If there good does that mean I can reload the os to a new drive with them? Do I have to use the exact same drive or does anyone know of another that will work? I guess i'm just hoping I don't really have to spend 1000.00 dollars on a hard drive. Any help or advice would be greatly appreciated.
    Thanks Judleroy
    Jun 2008
    1104
    Any old drive will do, although Western Digital were to be avoided at one stage. Best if it's sized larger than 400MB. Usual BIOS settings were:
    1024 cyl
    16 heads
    65535 wpcom
    1024 lzone
    50 sectors
    You'll need a copy of the file combine utility and a copy of the bootsector loader.
    FDISK the drive to have a primary 10MB partition (set as active).
    FDISK the drive to have a secondary (D:\) partition using the remainder of the drive.
    Format C:\ and volume name as EXECUTIVE_1
    Format D:\ and volume name as PART_PROGS
    Copy HURCO.LDR as the first file to C:\ (very important that this is the first file loaded after a format).
    Copy EXECPROG.001 from floppy to C:\
    Copy EXECPROG.002 from floppy to C:\
    Run the file combine utility to make EXECPROG from the two smaller files.
    Add the V1 Bootsector from the utility disk.
    Copy the rest of the files from your floppies to the C:\ keeping them in the same directories as they were in in the floppies (ie: A:\config\v1_64\vector4.sys must be copied to C:\config\v1_64\vector4.sys)
    Copy the LEADSCRW. file to C:\
    Job done.
    (All the above is assuming you had version 1 software).
    Dec 2006
    406
    Bloke thanks again for your willingness to help and expert advice. I'm in the process of moving the machine to a new location and setting it back up so it will be a week or two before I get to try things out. I'll let you know how it works out. I'm guessing the files you listed should be on the four backup disks. I think its around ver 1.7 of the software.
    Judleroy
    Feb 2010
    163
    When you get that machine set back up, I can give a hand setting up a flash drive instead of a hard disk, if you'd like. You should be able to get a Compact Flash card, and an IDE interface adapter for less than $50. This arrangement is what I have been using in all my embedded PC's for that last 5 or 6 years.
    Aaron
    Oct 2007
    269
    Quote Originally Posted by fasto View Post
    Aaron
    The flash setup sounds interesting.
    Dec 2006
    406
    Thanks fasto that would be awsome! Would I load the software onto the flash card just like it was a regular hard disk? Would that mean I don't need to get a replacement hardrive? If so i'm all in and appreciate it!
    Judleroy
    Feb 2010
    163
    Judleroy, yes, you would do all the steps that Cliff outlined, just using the flash disk instead of a hard drive.
    In a quick Google search, I found "Syba SD-CF-IDE-DI Card reader" for about $7, then the flash card of your choice.
    Remember, though, flash cards have a short life if the host operating system writes data to them frequently. I don't know what OS the BMC30 uses, or how much it writes to the hard disk. Modern Windows systems, XP & Vista, are very bad about this and write data to the hard disk almost continuously. I have used Windows 98 off of a flash card, and I think it worked OK. Regular MS/DOS works fine.
    You might want to make 2 flash cards, just in case the first one has a short lifespan. This would keep you running, using the 2nd flash card, until you changed back to a rotating hard drive.
    In my case, the equipment that I build uses embedded linux, and I have disabled writing data to the flash card (except for certain very specific files). I have not had a flash card wear out in 5 or 6 years of use.
    Dec 2006
    406
    I believe that the hurco is a dos based program. The operating system is ultimax 3. I think thats right atleast. It is a hurco dedicated system. The machine is a 97' and the original hard drive was less then 1 gig. I hope to be able to use a large sd card to be able to hold more programs. I have a few more questions if thats ok. Will this work just like there were a real hard drive?(able to delete unused program or is info permanently written to drive) Also can I replace my 3.5" floppy drive (after using it to load the backup disks) with one of these ide sd card readers. If so that would be great because it really sucks breaking up programs to fit on 1.44mb floppys. The machine does have rs232 ports but I have yet to find a cable that would actually work for dnc. I do know the ports test good but can't find a source for a working cable. Anyways I do like the convienence of the floppy but sd sounds better.
    Thanks again
    Judleroy
    Feb 2010
    163
    Hi judleroy,
    the Compact Flash works exactly like a hard drive. You can put files on it, delete them, rename them, whatever. The only difference is that you can put files onto and delete them on a hard drive essentially forever, but the Compact Flash card (and all flash based technologies) can only be written to around 100,000 to 1 million times. The CF card has automatic wear leveling, as it's called, to distribute the writes across the flash memories inside, but they eventually wear out. A DOS based system will last much longer than, say, Windows XP - this is because Windows XP is continuously re-writing the swapfile on the hard disk.
    To replace a floppy with a flash disk is possible but it is not a drop in replacement. Some companies make a device that pretends to be a floppy drive to the computer, but you plug in a flash disk of some sort. I don't have one of these and I haven't used one. I can't remember what companies make them. Try a search using "floppy disk emulator" or some words like that, they'll probably turn up.
    I won't have to worry about these issues, because my Ultimax 2 system boots from a bunch of EPROMs (if I can ever get it working). I do have floppy drives, though I don't know what they're used for or if they work. I haven't got that far, yet, still trying to fix the servo drive.
    I'm sure that we can get the DNC working once the machine is back running.
    Aaron
    Jan 2007
    203
    I think that the Ultimax 3 is build on Unix.
    What is the advantage of having a flash drive over a HDD? I don't see it!
    We still have a 1991 BMC20 setting around that was a demo before our company purchased it. the Mill has a Seagate 1.2G HDD and has never failed yet.
    All comments made are my opinion!
    Dec 2006
    406
    The problem is that my hard drive has failed. I think the advantage of the sd card for me would be that I can make a copy of the disk and when it fails I can just change out the disk. Hopefully I will also be able to store a hard backup in my home computer to have a way to make new sd cards. Lastly I think I could benifit from being able to take the sd card out of the machine to add and remove G-code files and do disk cleanup. I will have to see how it works out.
    Judleroy
    Jun 2010
    HI!HI!
    I have one Hurco bmc 30 with Ultimax 2 controller ,I can connect with Ultimax 2 controller via RS232 ports and transfering My G_codes Programs to cnc machine But ,not more than 60kb capacity,Please advise me How I can Transfering longer Programs via DNC Connection??
    Jun 2010
    HI!HI!
    please ,some body told me why my hurco/ultimax 2 fllopy drive dosse not work ??
    May 2008
    Hawk 5M Hard Drive Backup
    Hi all:
    My first post here.
    I recently acquired a sweet Hawk 5M. No software options (turbo and exactor only) but excellent iron. I am somewhat computer savvy, going back to DOS 3.0, and so tried copying the hard drive using Acronis. Although Acronis is most highly recommended (IMHO) for backup of modern computers it is useless for this job. I had to call in a gray beard Special Ops friend to complete the job.
    I can confirm, contrary to what Hurco tech support had to say, that the hard drive can be copied. It is satisfying knowing that I have at least one hard drive which can be popped into the MoBo at any time. The devil is always in the details and actually doing the dirty deed is a bit more complicated than what at least 2 generous members have spelled out. Many thanks for the leads on the basic procedure.
    Next, and this should probably be a new thread, the software security device, (dongle) also needs a backup. I recognize this device installed on the parallel port of the computer as a Dallas (now Maxim) ibutton device. Mine is a Dallas 1410D ibutton holder and the 1425 ibutton which controls the software. The 1425 ibutton actually has an itty bitty little battery which is good for ten years according to Dallas and mine is in it's 11th year, a subject for concern. Hurco tech initially told me that a replacement would be $90, certainly reasonable, but upon placing and paying for the order, the price climbed to almost $500, not reasonable.
    If your dongle fails, you will not make any chips. Any thoughts on this matter?
    Peter
    Jun 2008
    1104
    The hard drive may be tricky to copy but is a lot easier to make up from scratch. Ten minutes at most if you have the little utility files. I made a copy a few years ago using Laplink - it worked ok but it still needed the Hurco.ldr file to be copied first and the boot sector file running last.
    As for the dongle, it was probably $90 for the blank insert part but $500 for the programmed part.
    Sep 2010
    hi,
    i have BMC30 hurco with ultimax 3 but, failed hard disk and information. who can help me?
    Jun 2006
    7
    Bios setup for disk in max 32 DSP
    [QUOTE=bloke;730283]Any old drive will do, although Western Digital were to be avoided at one stage. Best if it's sized larger than 400MB. Usual BIOS settings were:
    1024 cyl
    16 heads
    65535 wpcom
    1024 lzone
    50 sectors
    How can I review or confirm the bios setup for disk in MAx 32 DSP system?
    My old segate with capacity 103mb is dead so I would like to put segate with 546mb ( with is in very good condition). If I simply exchange disk during loading data form floopy I receive error "disk-subsystem.....to inintialize".
    My BMC20 has 4 axis so it's really busy machine in my workshop since two weeks is off.
    Any idea how to bring my BMC 20 to life?
    Jun 2008
    1104
    To review the bios, hold down the "clear" key while powering up the machine.
    Jun 2006
    7
    clear key is not working
    if i push clear key - machine is also loading software from floopy
    Do you know any other ways to enter bios?
    software v1.31 MAX32 DSP
    also lookng for way to:
    Jun 2008
    1104
    Aha! you have the old 386 CPU with the fixed BIOS. The hard drive will be set up much more easily by FDISK and format in an old desktop PC using the hard drive settings from the old drive.
    The BIOS parameters on your CPU are stored in two EPROMS that set out the cylinders, heads and sectors and how much memory it has.
  1. hard drive
    By stevieboy in forum HURCO
    Last Post: 03-28-2012, 11:35 PM
  2. DX32 hard drive (DOM Flash thumb drive) replacement procedures. WIP
    By Cellar Dweller in forum Bridgeport / Hardinge Mills
    Last Post: 01-06-2012, 05:26 AM
  3. HAAS VF3 hard drive or no hard drive
    By teal854t in forum Haas Mills
    Last Post: 08-18-2010, 03:27 PM
  4. hard drive on cnc
    By keithmech in forum CNC Machine Related Electronics
    Last Post: 08-27-2008, 03:06 AM
  5. Hard Drive
    By larry53 in forum Computers / Desktops / Networking
    Last Post: 01-04-2008, 10:19 PM
