586,389 active members*
2,954 visitors online*
    Jan 2010
    294
    Tooling suggestions
    Im looking to cut some simple parts, and would like to mill a slot/groove for a spring clip. I dont have a lathe, and am not sure what type of tool would be best for this, I found these http://www.grizzly.com/products/Conv...8-Radius/H3341
    Would that be an appropriate tool to cut a horizontal groove?
    Thanks!
    Nov 2009
    724
    look for a slitting saw + manrdrel the same thickness as the snap ring you are planning on using, you can find then in any thickness down to the gnats a@#
    Nov 2005
    264
    FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
    Jul 2007
    1602
    Your drawing is showing a square bottom and the cutter you are linking to would give you a round bottom so I don't think it would be ideal for a spring clip. As was mentioned, a slitting saw would work well. A woodruff cutter might also work if the groove you are cutting is quite wide.
    I know you didn't ask for it but this post has some G-Code for doing something similar: http://www.cnczone.com/forums/showpo...7&postcount=43
    bob
    Mar 2006
    58
    A woodruf cutter could also work. I have used them before to make retention ring grooves in parts that would be difficult to turn.
    Jan 2010
    294
    The groove type doesnt matter much to me, its only purpose is to retain a clip. The slitter saws are much cheaper than the cutter I linked to, which is good- but I wonder if they will last very long.
    Thanks for the info guys
  1. Any Suggestions?
    By trampus in forum Okuma
    Last Post: 01-28-2010, 03:00 AM
  2. Suggestions please
    By MackBMF in forum Controller & Computer Solutions
    Last Post: 08-04-2009, 05:26 PM
  3. HI everyone...I need some suggestions...
    By rockappalla in forum Musical Instrument Design and Construction
    Last Post: 02-04-2009, 11:23 AM
  4. tooling suggestions for machining uhwmpe on cnc lathe
    By jpwestside in forum CNC Tooling
    Last Post: 09-30-2008, 02:43 PM
  5. Tooling Suggestions for V-bits?
    By Mr. Technical in forum Engraving Machines
    Last Post: 10-13-2007, 10:48 PM
