586,391 active members*
3,118 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Poor surface finish
    Mar 2008
    25
    Poor surface finish
    I was able to create and cut a contour of it but the finish wasn't what I anticipated? I used a ball end cutter but ended up with ridges between cuts. What am I not doing correct? Am using 9.1
    Thanks in advance.
    Mike
    Jan 2010
    Talking poor finish from ball mill
    Sounds like from what you described that your step-over amount is too large creating the ridges you referred to. Depending on the size of the tool, you can only step over a small amount so your cuts overlap a little to prevent excess material being left behind.
    Jun 2005
    305
    I agree, your stepover value is too large for the radius of the cutter.
    For roughing, I used 1/4 to 1/8 the diameter.
    For finishing, 1/10 to 1/20 the diameter.
    Even smaller on a few pieces for some medical parts I made a few years ago.
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
  1. 64 RMS Surface Finish?
    By pzzamakr1980 in forum MetalWork Discussion
    Last Post: 01-13-2009, 11:19 AM
  2. Surface finish
    By chakaloso in forum Uncategorised MetalWorking Machines
    Last Post: 06-13-2007, 02:54 AM
  3. surface finish
    By fadalman in forum BobCad-Cam
    Last Post: 03-03-2007, 08:30 AM
  4. Surface finish
    By d.a.v.e in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2006, 08:35 PM
  5. 32 surface finish
    By mroy0404 in forum MetalWork Discussion
    Last Post: 05-29-2006, 03:02 AM
