587,362 active members*
3,675 visitors online*
Results 1 to 8 of 8
Hybrid View
    Dec 2009
    12
    Mazak Fusion 640 T Keyboard
    I need to connect a pc keyboard to my QT200 with a 640 T control. For some reason I was not able to install the pcmia network adapter and when I rebooted the machine it came up with a error. If I could "press any key to continue" I could get into the registry and fix the issue. The error is very common with Win95 and easy to fix.
    Can anybody help me out?
    Philip
    Apr 2006
    3206
    open up the face of the control....there's a connector for the keyboard up around the top, towards the left as you're looking from the rear as I recall.
    I'll open mine in the morning and double check..and post back here. Expect around 8am PST
    It's easy.
    Jun 2022
    28
    Re: Mazak Fusion 640 T Keyboard
    Quote Originally Posted by fizzissist View Post
    It's easy.
    i know this is a decade old thread but regarding the fusion640 control pad
    if the buttons are hard to push or if there is a play ...is something going on inside ?? or is this electrical?
    Jul 2007
    284
    There is a PS2 connection is on the back of the keyboard. It is located below the hard drive. The connector faces side ways. You'll have to reboot so that the PC recognizes the keyboard.
    Dec 2009
    12
    Problem fixed, thank you for the help .
    Philip
    Mar 2006
    42
    I would love to know how the error was fixed i just got the same error!!!
    Dec 2009
    12
    I solved the problem by properly installing the pcmia network card. You'll need the keyboard attached to your machine to do this.
    Philip
    Hello, people!
    I have a huge problem for 5 days we cannot start our CNC Lathe 5-axis Mazak Integrex Y200.
    The control is Mazatrol Fusion 640tm.
    The machine was working fine all day and all of the sudden the computer powered off !
    After we powered up the computer again there was an ALARM - BATTERY LOW. We changed the battery the Alarm went off.
    However, when we restarted the computer we still cannot continue with loading. Now there is an alarm that KEYBOARD IS NOT DETECTED... PRESS [F1].... or [F10]...
    The keyboard of the Control panel is of course not working....
    We connected several keyboards with PS2 at the back of the control panel.
    When we restart the computer at startup the keyboard lights up for a second but when the system loads to the ERROR we cannot continue. The keyboard does not make any input.
    PLEASE HELP! We need the machining running ASAP!
  1. fusion mazak mill
    By wireguy in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-01-2014, 02:48 AM
  2. A little help with MAZAK FUSION 640-T
    By dinudesign in forum European Club House
    Last Post: 06-06-2012, 02:05 PM
  3. Mazak 640 t fusion Parameters
    By Sirwhinesalot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-29-2010, 01:20 AM
  4. Mazak 640 m fusion question
    By nightshift in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-13-2007, 06:50 PM
  5. Probing - Mazak Fusion
    By CFisher in forum Digitizing and Laser Digitizing
    Last Post: 06-08-2005, 05:02 AM
