For squaring, one way would be to go with a machinist's level and machinists square. Square the frame and then level all the pieces in both planes. It's a pain in the rear, but it works. Although with your rails on the outside of your frame, that will be a little tougher... If your frame is level across the top in both planes, the sides are at the same angle to the top on both sides and the frame is the same width along its entire length, you could just measure down from the top of the frame to locate your rails. You can get cheap machinist's levels from Grizzly and similar places, or bigger more expensive ones from companies like Starret for significantly more money. I think I bought my squares from MSC and they were Spi's on sale for reasonable prices. Basically the same deal there - the bigger and more accurate the square, the more it costs.
