586,393 active members*
2,942 visitors online*
    Jun 2009
    21
    Feeds and Speeds
    I’m new to CNC Programming. I am trying to work out speeds and feeds of a 7 tooth carbide milling cutter. The material is mild steel.
    The information on the carbide inserts are:-
    Vc (m/min) 350 – 150
    Fz (mm) 0.05 – 0.15
    Ap (mm) 0.1 – 2.0
    Dia 63mm
    Using formulas I have worked out the following
    Vc = 150
    Fz = 0.15
    Ap = 2
    Teeth = 7
    Dia = 63
    RPM = 793
    Feed = 833
    It would be much appreciated to have a second opinion on these results before I start machining.
    Many thanks.
    Mar 2006
    58
    Using your data, I calculate 758 RPM and 722 mm/min. I am in the US so I converted to in/min to make sure it looked right, and it does.
    Fegenbush
    May 2005
    2502
    Quote Originally Posted by Fegenbush View Post
    Fegenbush
    Yep, G-Wizard gets the same answer.
    Best,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Jun 2009
    21
    Quote Originally Posted by BobWarfield View Post
    Best,
    BW
    Thank you all
  1. Feeds and Speeds
    By tac8357 in forum Mentors & Apprentice Locator
    Last Post: 06-26-2008, 03:50 PM
  2. Speeds n Feeds
    By jessbussert in forum WoodWorking Topics
    Last Post: 06-12-2008, 05:09 PM
  3. speeds and feeds
    By stevieboy in forum MetalWork Discussion
    Last Post: 03-09-2008, 03:55 PM
  4. Need some help with speeds & feeds
    By ldkell_2000 in forum MetalWork Discussion
    Last Post: 03-01-2008, 05:35 PM
  5. feeds and speeds
    By rchprks in forum MetalWork Discussion
    Last Post: 07-18-2006, 12:48 AM
