586,983 active members*
3,793 visitors online*
    Jun 2009
    21
    Help Please Feeds and Speeds
    I’m new to CNC Programming. I am trying to work out speeds and feeds of a 7 tooth carbide milling cutter. The material is mild steel.
    The information on the carbide inserts are:-
    Vc (m/min) 350 – 150
    Fz (mm) 0.05 – 0.15
    Ap (mm) 0.1 – 2.0
    Dia 63mm
    Using formulas I have worked out the following
    Vc = 150
    Fz = 0.15
    Ap = 2
    Teeth = 7
    Dia = 63
    RPM = 793
    Feed = 833
    It would be much appreciated to have a second opinion on these results before I start machining.
    Many thanks.
    Jul 2008
    411
    Yes, close enough.... I'd go 750rpm, 800mm/min but like all things you need to experiment with your machine to get a feel for whats its really capable of. Thats a big cutter, you might need to start at slightly slower spindle speed (say 600rpm) and feed rate (say 450mm/min) (that's a feed/tooth of 0.1) and and see how it goes then ramp it up...
    A lot will depend on the rigidity of your mill!
    If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com
    Jun 2009
    21
    Quote Originally Posted by irving2008 View Post
    Thank you
  1. Speeds n Feeds
    By jessbussert in forum WoodWorking Topics
    Last Post: 06-12-2008, 05:09 PM
  2. Feeds and Speeds
    By sjotime! in forum Mach Software (ArtSoft software)
    Last Post: 02-17-2008, 10:46 PM
  3. Help! with Feeds and speeds please!
    By sjotime! in forum Visual Mill
    Last Post: 02-13-2008, 07:56 AM
  4. feeds and speeds
    By porkchop21 in forum Bridgeport / Hardinge Mills
    Last Post: 08-31-2007, 01:52 AM
  5. Speeds and feeds
    By Hack in forum MetalWork Discussion
    Last Post: 10-15-2005, 04:47 PM
