586,126 active members*
3,035 visitors online*
    Jan 2008
    24
    SIEMENS 810D NEWBIE
    HI all,
    I am a total siemens 810d newbie,we got bought a new machine at work with it on,and i self taught myself more or less,anyway i got a problem,is there a code to put in the program for the tool mag to index into position for the new tool while the machine is machining?
    SUB CONTRACT MACHINING,CNC PROGRAMMER USING POWEMILL,MASTERCAM,MECHNICIAL DESIGN ENGINEER USING AUTOCAD,INVENTOR,POWERSHAPE www.cadtechuk.co.uk
    Dec 2009
    11
    That would depend on if you are using tools that are locked in the magazine (oversize or offset)or that can be freely moved around? Typically just the tool number with no tool change call out will advance the mag.
    Dec 2009
    11
    That would depend on if you are using tools that are locked in the magazine (oversize or offset) or can be freely moved around. Typically the tool number with no tool change request info (no M6) will advance the magazine to the next position.
    Dec 2009
    11
    Sorry for the double message. Did not think the first one went through. forgot to refresh browser.
    Nov 2007
    30
    what type of machine did you use? i'm using 810D with deckel maho machining center
    Oct 2009
    27
    call the next tool in GCode as you normally would, but omit the M6, this preselects the tool. It will only do the actual toolchange on receiving M06.
    Put the preselecter call straight after the M6 / M06 of the tool you are using.
    Only works on sidemount ATC's with twin gripper arm as far as I am aware.
    If that makes any sence?
    John
  1. Siemens Sinumerik 810D offsets
    By lenny2007 in forum G-Code Programing
    Last Post: 06-20-2010, 09:57 PM
  2. SIEMENS 810D PC CARD activation ???
    By lentrisca in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-04-2007, 12:17 AM
