586,409 active members*
3,045 visitors online*
    6
    Mister cooling??
    I'd like to know if anyone has fabricated a misting system for a mill or lathe to provide cooling. I'm learning how to use a mill and a lathe I purchased about a month ago and am trying to avoid the mess of flood cooling. I'v experimented with spraying the workpiece with brake cleaner from an arosol (sp?) can. I'm not sure if it's a smart thing to do...... but it seemed to cool the work about 40 degrees. ( Peaked at 160 and cooled it to about 120. ) I was trying to turn some round stock down to a point for a hay fork.... It seemed like a good project in which to learn about running a lathe.
    If anyone has any ideas, I'd sure be interested to hear. Or if I should abandon the idea. It would be nice to know befor I destroy my new tooling.... It's cheap tooling but I'd like to make it last... Thanks Everyone!!
    49
    Mister cooling
    I would be careful with brake cleaner. WD40 is what I use and it much cheaper. I am looking for a non flammable alternative. Look at Enco they have mist coolers for around $200. Magnetic base so it should work on a lathe as well as mills.
  1. Vortex air cooling
    By kong in forum Uncategorised MetalWorking Machines
    Last Post: 10-08-2008, 07:55 PM
  2. Water cooling CPU
    By cncadmin in forum Computers / Desktops / Networking
    Last Post: 07-13-2006, 11:30 PM
  3. Is there any cooling liquid homemade formula?
    By jlagran he in forum MetalWork Discussion
    Last Post: 12-14-2004, 04:33 PM
  4. Flood cooling rocks!!!!
    By JFettig in forum Benchtop Machines
    Last Post: 09-17-2004, 11:01 PM
  5. Cooling Head
    By motomitch1 in forum Hobby Discussion
    Last Post: 02-06-2004, 07:30 AM
