586,983 active members*
3,627 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > rebuilt 2.5 - stepper to servo conversion
Results 1 to 20 of 23
    Nov 2007
    197
    for the past few months i've been agonizing over how to improve the speed a reliability of my Y axis.
    Theres the back ground.
    Swapped all screws to 1/2-10 5 start to help improve the speed, but was not happy with the lost resolution
    Typically what i find while running production jobs is the origin slowly starts to drift - after about 20 -30 parts its off .020".
    Beyond that, my rapid on the Y axis was only about 100ipm because the motors would sometimes stall.
    The motors / drives when i first built my machine were poorly selected - live and learn.
    Keling 425oz Nema 23's. Require 84v but i'm feeding them with 38v
    Keling Stepper drivers which are limited to 40v max
    I was up against replacing four drives, and getting a larger power supply.
    Even though that would have been cheaper, I decided to try my hand with servos
    Here is the machine
    Here are the two Y axis motors
    After much debate between the Gecko and Viper servo drives, I decided to go with the Viper 95 drive
    Servo Motor I selected
    Keling KL23-130-60 (NEMA23)
    Skewed Rotor Design, 60V/20A
    Constant Torque: 50 oz-in
    Peak Torque: 350 oz-in
    No load Speed: 4700 R.P.M
    Terminal Voltage : 60 VDC
    I'm still going to be driving these motors with my 38v power supply to help limit the RPM.
    My goal is 4:1 reduction, and a max Rapid of 300 IPM. Based on the screw pitch, that will require 2,400 RPM
    I searched high and low for an afforadable gear reduction system, but finally settled on this belt system i found on ebay
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=250563161378
    I'm hoping all these parts show up soon, so i can get things going.
    I typically plan my upgrades around new production jobs and I have one coming up in a week or so that I need to be ready for.
    First plan is to switch the Y axis, and then continue to convert the X and Z as money allows
    Sep 2005
    1195
    Why not using bigger motor such as KL34-180-90. If you use belt for driving 2 motor in x axis may have problem with synchronizing speed?
    Nov 2007
    197
    i'm pretty confident the 425oz motor is enough if i was able to power it properly.
    That would mean 84v power supply - roughly 150 bucks
    4 gecko drives, 150 each
    So thats 750 bucks to stay with stepper technology
    I decided i'd rather move to servos on this build, and save the motors and drives for a less taxing plasma table i'm working on at the same time
    You probably could have gotten better performance by going with smaller steppers. The 425oz motors are notorious for offering poor performance with low voltage, inexpensive drives. They are a very poor choice for small routers.
    And lowering the acceleration would probably get rid of you're .020 error. You must have been losing steps somewhere.
    I get 170ipm on my Y axis, with 1/2-8 2 start acme, a Xylotex, and 250oz steppers at 24V. And I've run it for 12 hours with no loss of of position.
    Nov 2007
    197
    I totally agree Gerry. In fact before i went down this road, i bought some smaller motors which better matched the voltage I had available
    I found that I could drive them much faster, but they still lacked the torque to drive the gantry as fast as I wanted.
    The error really showed up when i switched from 2 to 5 start screws. That reduced the number of steps required and really made the resolution course. I did then bump up the micro-stepping, but thats not always the best solution. I think i'm currently using 1/16 stepping.
    So yeah - i definitely could have stuck with steppers, matched the drives and power supply and kept going.
    just thought servo's might be fun
    I just finished a nice job here at work using Allen bradley drives and motors, and a nice THK ball screw assembly. That thing seriously hauled ass. so i'm a little bit addicted. next i'll be swapping out my acme screws for ballscrews
    Nov 2007
    197
    got a few items in today, and installed
    first half of the belt drive
    all bolted up with the Keling Servo motor
    I went with 500 count US Digital encoders, here's a close up of the wheel
    so with two revolutions per inch, and 4:1 reduction - i get 4000 pulses per inch. which equals .00025 per step
    i got anxious and powered up the one motor directly to see how quick the table moved. of course i disconnected the slaved screw first. It traveled 48" in about 10 seconds, which gives me just under 300 ipm. I'll be happy if I hit that number once all is done
    these motors are rated at 60v, and 4700 max rpm. my power supply is 38v and i'm estimating around 2400 rpm at this voltage.
    500 count encoders need 2000 steps per rev. At 2400 rpm, that's 80,000 steps per second. Do you have a PC that can do that?
    Nov 2007
    197
    Yes and no.
    My pc is good up to about 75k, but I wouldn't want to push it that hard
    Viper servo drive has a built in step multiplier, which defualts at four. From there you could go higher, but would start to loose resolution. At four no resolution is lost, an the drive has some overhead to position itself
    It was one of the main reasons I went with viper over gecko. Beyond that, it has a few other variables that should make the setup really nice
    Nov 2007
    197
    well i waited what seemed like forever for my viper 95 servo drives to show up. They finally made it here friday, and a few hours later i was making things move!
    please excuse the mess in the photos, the next step will be to redo all of the wiring on the machine which has slowly gotten out of control over the years
    I experimented with two drive ratios - 4:1, and 5:1. Ultimately 5:1 won out, due to the slightly higher torque it produced. With 4:1 i was still able to stop the table by pushing on it. 5:1, I was not able to stall
    This limited my current IPM to 220, which is plenty fast. To go faster, I need a higher voltage power supply. I currently have 38, and would possibly step up to 58 - however I wouldn't be able to use all of that voltage - the machine would be way too fast
    Along with the motor conversion, i also removed, cleaned and dry teflon sprayed my screws. I also figured out why my X and Y were slightly out of square and was able to fix that easily.
    good day in the shop!
    [ame="http://www.youtube.com/watch?v=BuqncJi2eEQ"]YouTube- cnc router - y axis servo motor conversion[/ame]
    Nov 2007
    197
    ok so like every project, this keeps going further and further.
    I've decided to move up to a larger power supply (56v), and switch all axis to servo. At the same time, i'm redoing my control box to clean things up a bit
    cable carrier for the x axis
    one end of the electical cabinet, in progress
    I picked up this sweet 8 port usb to serial box on ebay for 40 bucks. Plan is to wire up all 4 Viper servo drives, plus my VFD.
    power supply, spindle drive and servo drives
    finished end panel, with servo drives and limit switch connectors
    powder coated, and then laser engraved
    here is the mill i do most of my work on. Milltronics Partner 5. works great!, although it did need some repair to get it going
    Hoping to get the panel done this weekend, and some more wiring squared away. maybe by next week it will be up and running
    Nov 2007
    197
    i guess this thread isn't very exciting
    finally finished up all the wiring on the machine this weekend. took way longer than i had expected! but everything fired up without a hitch
    best part is the 8-1 usb serial box. i can have a hyperterminal window open with each servo driver connected. I'm hoping that larken comes out with some tuning software for the servo drives, or perhaps i'll write a simple polling routine to grab some data and graph it
    only wish now is that the screws were more accurate. maping across the x axis, the beginning of the screw gains about .015" over 10 inches but then settles in, so it makes calibrating the screw hard
    Jan 2006
    628
    Hey, I think it's pretty exciting. Keep the photos and updates coming. The enclosure and engraved panels look awesome. Glad to hear the performance has worked out well for you. I'm curious if you needed to install any type of filter when the VFD went in the cabinet?
    My own stepper to servo conversion has been slow in happening. I finally have the last few enclosure components I need to get my wiring job finished. Everything has been tested on the bench and it looks great. I'm using 300W BLDC servos and the Granite VSD-E drives. I'm going direct drive and looking forward to the performance/precision boost.
    How are you mapping the screw accuracy? Do you have a glass scale, or is there a way to do it with the optical encoders and some type of dial indicator? One inch at a time?
    Steve
    Feb 2010
    331
    where did you get your power supply from?
    Nov 2007
    197
    thanks steve. at the last second, i did add an EMI filter prior to the VFD. i ran out of space on the cabinet panel, so its bolted to the top of the cabinet. Everything seems to be working just fine!
    i took a chance and used singled ended encoders to save a couple bucks. I was worried there might be some noise issues on the Z axis with the spindel wiring right next to it, but so far so good
    today i mapped the screw by just plunging holes in my table every 2 inches and measuring between them. previously i used a larger DRO (36" or so) to map the screw. Mach has a screw mapping feature, but it only applies when running specific g code functions - so once you start jogging, you loose the mapping.
    the power supply is made by antek, and available on ebay or direct. its really nice and includes 5, 12 and 56 volt terminals. beyond that, its fused for x, y and z axis with separate terminals. it makes wiring easy
    Jan 2006
    628
    Thanks for the info. I knew Mach had some screw mapping functionality, but wasn't sure what it applied to. I'm curious about this with my rolled screws and may do the "hole drill" test and dial caliper test at some point.
    I was considering moving my VFD into my cabinet, but it's kind of handy to have it on the wall right now. I don't have it under Mach control, so it's handy to have the manual control close by.
    Steve
    Jan 2007
    723
    Why not switch over to some of those cheap Chinese ballscrews? The precision should be slightly better than the rod and you will gain more torque from your motors from the added efficiency.
    http://www.glenspeymillworks.com Techno LC4896 - 2.2Kw Water Cooled Spindle | Moving Table Mill from Omis 3 CMM, 500Lb granite base | Epilog Legend 32 Laser Engraver
    Nov 2007
    197
    yeah that will probably be the next phase of the build, but i gotta recover the 1500 bucks or so i spent converting to servos, ha.
    whats funny is this machine has paid for itself 20 times over back when it was pieced together, but work is slowing down a bit so most of these recent upgrades have been for fun.
    Nov 2007
    197
    back for another small update. rebuild 3.0?
    i purchased two THK ball screw actuators which i will be using as my Z axis. They have approx 8" of travel. I'll be running these with the same servo setup i've previously used. 4:1 reduction, and viper drives.
    for spindles, i almost went full circle going back to a router. initially i purchased two 2.2kw spindles from china. not sure if i ended up with junk ones (or if all are junk and people are blind!), but they failed horribly my tests for runout, etc. Not to mention, they weigh a ton. Luckily i was able to return them for a refund!
    i searched and searched for other collet spindles, and didn't find much in my price range. I considered the PID speed control out there for routers now, but felt that was still a little questionable and time consuming
    luckily i stumbled on these spindles, being made in italy - Mototecnica. They are sold under a few different names but going direct gets great prices, and they have many sizes and bearing combinations available.
    previously i was using a 1hp perske spindle with great success. so i purchased two 1hp spindles from mototecnica. price was very reasonble (minus VAT tax), and came in shipped around 425 each.
    pluses over the Chinese spindles
    1. mounting holes provided (saves 50 bucks each)
    2. air cooled (saves 100 bucks?)
    heres a quick video of it wired up, controlled by my automation direct VFD.
    [nomedia="http://www.youtube.com/watch?v=q8fo9DPvDX8"]YouTube - mototecnica er20 spindle motor[/nomedia]
    will still be a few weeks probably until i'm cutting chips. I have a large job coming up again in January which requires machining with two different cutters on a number of pieces. this will dramatically cut down my cycle / setup time
    Feb 2009
    1290
    Very interesting thread!
    For someone looking at upgrading to Servos there is a lot of good info here. That spindle looks interesting, did you nmention what VFD you are using?
    Nov 2007
    197
    yeah for the VFD i'm using automation direct 1hp GS2 model. i still need to pick up another for the 2nd Z.
    most of my other parts have been collected. Another Viper servo drive, and i just ordered the servo from keling and encoder from US digital.
    i finished up all my mounts, and made one ball screw cover. (cut on my cnc plasma table :cheers
    heres a mock up of all the components
    next on the list will probably be upgrading the Y axis linear rails. The VXB 20mm rails with open bearings aren't cutting it. Too much weight hanging on them and if you push on the gantry, things move a bit. I have my eye on some THK rails
  1. planning an X3 conversion: Stepper or servo?
    By BiggerHammer in forum Benchtop Machines
    Last Post: 12-14-2010, 07:11 PM
  2. servo conversion vs stepper conversion
    By contractdesign in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2008, 08:54 PM
  3. RONG FU RF-31 Conversion Servo or Stepper
    By rpcaster in forum Knee Vertical Mills
    Last Post: 04-26-2007, 03:09 AM
  4. Stepper to Servo Conversion
    By runnoahrun in forum Servo Motors / Drives
    Last Post: 06-28-2005, 12:20 AM
  5. excello conversion stepper to servo
    By roonster71 in forum Bridgeport / Hardinge Mills
    Last Post: 05-03-2005, 02:15 PM
