586,667 active members*
3,606 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Whats better a Microkinetics CNC 1340 or retro fit the hardinge DV59 for Cannons
Results 1 to 14 of 14
    Hi Again you all
    This is my delima what i need the lathe for is to turn brass & titanium for scale cannons i have a DV59 hardinge lathe with a split bed. One thought is to convert it to cnc with mach 3 thk rail & ball screws for a x travel of 30 or so inches and 12 on the X. I fiqured it may run between 2-3 k.
    Or i have an opportunity to get a Microkinetics CNC 1340 lathe thats made in 2007 and has less than 2 hr on it reason why the low hours are because he is having the parts made elsewhere. he has around 13k in it and wants 6-8k is this a good deal.
    I had look in this forum for info on this lathe and its about 50/50 or so one guy here that makes paintball parts has one and is happy with it and another has problems with the tool path and usb port.
    Below are some images of the work that will be done on it. Again Thanks for any input information you may beable to advise thanks Austin
    Jun 2005
    1015
    the microkinetics deal depends on the accessories. i saw his ebay ad and really you can get a brand new microkinetics lathe with threading for $500 more than he's asking. if the micro sold for 3000-4000, then that might be a better deal. ultimately if your selling these you may want to drop a few quotes out there. you'd be surprised what you can get parts made from these days. you can buy alot of cannons for $8500
    Micro lathe
    Hi Their
    I had tried to get Quotes last year when i had to make 40 of those med size brass mortars and the best one was 30 bucks each in quanities of 100 but the problem is i have like 10 diffrent cannons i had made for customers and i had sold them at a good price and people like them there are one that other makers that want twice as much for but not as good. And i figure this CNC is low enough not the 8k but maybe 5-6k and since he's only 100 miles from me and i had spoken to him and i'm going to look at it in the morning and i think he said it does have the threading attachment and other tooling and accessories to I'll know more tomorrow. And this will be good for the Bersa 380 Titanium firing pins i had made one for mine and it works great. And i had some orders for 1/2 scale and 1/3 scale howitzer cannon and this bed is fairly long so. It would be great if i could get this made for less but no one would thanks Again Austin
    Quote Originally Posted by Runner4404spd View Post
    Thumbs up What A BIG Mistake I hade made MicroKinetics
    Well I now wish i hade retrofitted the Hardinge lathe. against fellow recomendations i went ahead and purched a used microkinetics CNC 1340 lathe and it has been nothing but problems. I sure i will have to re retro fit it with another controler and encoder unles i pay the 10% of 13k for the warenty transfer. I had read only good about this machine so i thought it was good but after getting it its been nothing but problems 1 was the polarity which was resolved on the x axis but also a threading issue in which after i spent $150 for which was cheap because i had posted a banner on my website but it still wasn't worth it because there only support is that i send the encoder back at a small fee. But with the issues so far i will not pay the $1,300.00 for the transfer of the waranty because from what i see so far there will only be more & more issues. I'd be better off re retrofitting this with a new controler so if you all have any ideas please let me know I'd like to run Mach 3 there software just doesn't work it times out if you know where to buy a kit let me know i should beable to use the drive i have i'll give you all the other stuff like the driverack subsystem its useless to me
    Thanks for any info Austin
    Feb 2007
    966
    Is that a stepper drive or servo. What type of drives are in it.
    Also how many lines is the spindle encoder ?
    Is the spindle variable speed ?
    Larry K
    Jun 2005
    1015
    the microkinetics lathes are stepper drive. also the spindle speeds are set with the gear box.
    Feb 2007
    966
    Are you sure you want to put linear rails on a lathe ? They have to be super rigid to get a good cut. The Dovetail ways and V type saddle is the best. You can an auto-oiler on the ways.
    BTW, Nice cannons.
    Hardinge lathe
    On my hardinge it has the split bed its an older type i which i had the dovetail one i have a piece of cast iron that's like 4 foot log by 18" by 2" thick and weighs a ton too i was going to face it on one side and mill the bed out so it would seat nicely on the lathe bed and have several bolts holding it down in the t slot. That would be after it was trued up for the rails but all this seems like way to much work. that's if i had the time. Thanks Austin
    Quote Originally Posted by Larken View Post
    BTW, Nice cannons.
    I wish i never bought the Microkintics CNC lathe to this day it has been nothing but problems. The only way i have been able to make this work is to generate my own code. Their software is nothing but ****. So any of you that plan onbuying from this company even the smallest of part BEWARE your buying nothing but headaches. You will regret it theirs not enough pain meds to help.
    I have seen CNCMasters unit which is the same but 100% beter because if issues do arise it still has the manual controls. I fully understand that by not spending over $100,000 for an CNC your limited But come on.
    So heed my warning Beware Nothing but HEADACHES
    Thanks AMG
    Mar 2012
    378
    I got some Microkinetics drivers, Optistep, motors, and software several years ago to convert a Sherline mill and had nothing but problems. I never could get it to work correctly. I would never buy anything from them again.
    Jan 2009
    234
    Re: Whats better a Microkinetics CNC 1340 or retro fit the hardinge DV59 for Cannons
    Since Microkinetics has bad customer service and i see a trend of buggy controllers anyone want to start a Open Source project for the MN400 Controller? Was planning this weekend to jtag in to it and have a look around (Found my self doing other things) the Xilinx, PIC18F,Eproms and DSP chips are fairly common and have great following for homebrew types!
    Machines: Grizzly G0704 Mill W/ 3-Axis DRO | Birmingham 12X36 Lathe W/ CNC Retrofit PMDX-126/107 W/ESS 3ph W/ WJ200 VFD
  1. Replies: 1
    Last Post: 04-08-2013, 07:51 PM
  2. Pocket Artillery Mini Cannons ***BOOM***
    By Vulcan R&D in forum News Announcements
    Last Post: 11-02-2011, 03:39 PM
  3. Help With Microkinetics 1340 cnc lathe
    By saberforge in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2011, 08:33 PM
  4. What cold be the issue on return to start Microkinetics 1340
    By TitaniumCannons in forum Uncategorised MetalWorking Machines
    Last Post: 04-21-2010, 08:16 PM
  5. Hardinge DV59 CNC retrofit
    By Captdave in forum Hardinge Lathes
    Last Post: 07-31-2008, 02:05 PM
