We have a 95 VF-2 with a 7500 RPM spindle with gearbox. I am trying to isolate a noise the shows its head at around 2200 RPM in high gear. It almost sounds like a bad bearing however I feel it cant be because if I raise or lower the RPM it goes away and never shows back up. The encoder belt is showing signs of cracking so that will be changed. The main spindle belt also is prob the original belt so we want to change that at the same time is it dosent require more than a few hours of work. Whats the easiest way to remove this belt?
