586,471 active members*
4,242 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > What is the Difference between 6000 series aluminium and 7000 series
    Feb 2005
    5
    Hello everyone
    I just wanted to ask anyone who can help me out and tell me the difference in machining 7000 series aluminium and 6000 series.
    Job is 7000 series material 3000mm x 2000 x 90mm thick
    Heve to cut a profile with a 50mm cutter hoping for 10mm depth of cut.
    Does 7000 series machine different to 6000 series
    Is it easier or harder to machine.
    If you have any suggestions please e-mail me [email protected]
    Thanks guys
    Kosta
    Jun 2004
    487
    Hey Kosta,
    7 series is much harder than 6 series and more difficult to machine - to a certain point. The thing is that it's so hard (for aluminum) that chips don't generally stick to the endmill like 6 would.
    You can check out the specs, might answer your questions. BTW, that site has an amazing amount of information on different metals and alloys - it's got a buttom on my browser so I have it for quick reference.
    JR
    Jun 2003
    513
    The 7000 series is a higher strength alloy than the 6000 series and contains larger amounts of zinc & magnesium. In general, aluminum such as 7075-t6 does not require heat treating after welding.
    The 7000 series is a little tougher to machine compared to 6000 and tends to be more free machining. It is not as ductile. When machining any aluminum you do not want the chips to stick to the endmill. If you have a problem with that it could be feerates too slow, rpm too fast, wrong number of flutes (too many) when slotting/pocketing (chips not evacuating), depth of cut too deep, or lack of lubrication/coolant.
    7000 series corrodes more easily than 6000 and will discolor quickly when using synthetic coolants.
    Jun 2005
    6
    ..old but very usable tip : use alcohol as cutting liquid...no chipping problem after that.
    Mar 2009
    1863
    Quote Originally Posted by cadman View Post
    You CAN NOT WELD 7075 aluminum.
  1. 7000 Series Aluminum Drops For Sale
    By dneisler in forum News Announcements
    Last Post: 05-19-2013, 02:14 AM
  2. Centroid 400 6000 series
    By bakarack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-10-2008, 12:12 PM
  3. Aluminium 7000 series
    By formwell in forum Material Machining Solutions
    Last Post: 06-21-2006, 09:11 AM
  4. How does this BP Series 1 look for $6000??
    By NOCARRIER in forum Bridgeport / Hardinge Mills
    Last Post: 04-19-2006, 05:13 PM
