586,624 active members*
2,469 visitors online*
Results 1 to 3 of 3
    Jan 2010
    2
    Red face Display massage : BROKEN WIRE
    I have a Megaplot s foamcutter. It worked exellent, but it stopped in the midlle of the work ; with the message " BROKEN WIRE" . I have replaced the wire, checked the fuses, replugged, restarted; changed (BT139 and MOC3052) but I still have the same problem.... Machine is moving O.K on the X and Y os but when I want to turn the wire on it turns on for a "second " and then turns of...
    I need Help !!!
    Jul 2007
    1602
    Is it possible that one of the wires that feeds the cutting wire is broken (probably under the insulation) or has become disconnected? If you have a multimeter, you should be able to verify that easily enough.
    Jan 2010
    2
    Thanks Rowbare.... I will check that.
  1. Wire EDM - Wire Type and Size
    By greenchair in forum Uncategorised MetalWorking Machines
    Last Post: 06-17-2009, 07:44 PM
  2. power supply size? for multi wire (total 250 inches of wire)
    By DanOSB in forum CNC Wire Foam Cutter Machines
    Last Post: 03-02-2009, 11:34 PM
  3. How to wire an 8 wire stepper motor
    By technosteve in forum DIY CNC Router Table Machines
    Last Post: 01-17-2009, 12:01 AM
  4. Laser Operator Massage
    By ounsiam in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-19-2007, 05:05 PM
  5. broken tap
    By T.L.A.R. eng in forum MetalWork Discussion
    Last Post: 02-25-2007, 12:38 AM
