milltronics milling machine VK3 will run all drill cycles but will go to DOS trying to run any mill cycle.Deleted all program files and uploaded parameter file.Same problem could anybody help.THANKS
Error 201 is a Range Check Error. Something (parameter, program input, etc..) is out of range or too large. The DOS error contains an address number and software version. What is this?
Hi Jpawelk
The DOS version is 6.22 and the address is 0019:15BD
The software version of the Milltronics software, not the DOS version.
Hi Jpawelk
3 AXIS SLS CNC 6.3159p FLASH
Thank you
