586,192 active members*
3,905 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > mach3 spindle control on nm-200
    Nov 2009
    122
    hi all, i pulled trigger and bought the nm-200 a while back, and i have it all setup, and everything works but the spindle control is all or nothing. i changed some stuff around as per info found while researching, and i can get it to control speed, but actual speed is double what i put in. it works when set to 50% but that cant be right. i tried installing the novakon nm-200 xml file off both the usb key included and off the website, and both when insatlled/open mach with that profile cause everything to fail. nothing moves except the dro number change according to the program or jog commands. when i reinstal the mach3mill.xml, everything works except spindle control. hope that is clear enough. i was wondering what some of you may be using for spindle control settings in ports and pins/spindle control? thanks
    Nov 2009
    122
    update. i just went back out and tried messing a bit more and changed some of the spindle control numbers in the motor tuning config, spindle axis, and it got better, so i kept adjusting until my hand held meter read pretty close to all the different S numbers i kept throwing at it, so i feel a bit better. i went into motor tuning, spindle axis, and changed steps to 1000, and velocity to 700, and it seems to work. that doesnt jive with anything i have read, so i think the pulley settings and min and max speeds need to be set. i would still like to know what settings anyone may have under ports and pins, spindle. and also under motor tuning, spindle axis. thanks
    Dec 2009
    594
    Jesse,
    I posted on the other thread, but should done so here.
    Are you using the motherboard upgrade in the CD-100, or your own PC? I am about to order a NM-200 with the CD-100 upgrade, and would like to assume that my machine will be properly configured and tested before it it shipped.
    Thanks for any information.
  1. Setting up Spindle Control in mach3
    By UKRobotics in forum Mach Mill
    Last Post: 10-18-2009, 10:34 PM
  2. Spindle Control Problem in Mach3
    By creativecad in forum Mach Software (ArtSoft software)
    Last Post: 08-07-2009, 12:57 AM
  3. Mach3 spindle control of Boxford 260 VMC
    By jwhitley in forum Benchtop Machines
    Last Post: 09-09-2008, 06:21 PM
  4. VSD-A Spindle control in MACH3?
    By mkuivamaki in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-08-2008, 08:09 PM
  5. SX3 spindle speed control with Mach3
    By bbox in forum Benchtop Machines
    Last Post: 07-05-2008, 11:15 PM
