586,263 active members*
3,750 visitors online*
Results 1 to 1 of 1
    Sep 2008
    68
    SOLVED...Mazak QT20 several alarms
    Some weeks ago I serviced the above mentioned machine, it used to show 3 alarms on the screen:
    a) 201 - Breaker trip
    b) 221 - Turret clamp sensor malfunction
    c) 33 - Emergency stop
    The machine had been just sitting there for more than a year when I was called in, actually I was the third tech in the lineup. Originally the spindle drive of this machine was sent to Mitsubishi for a mayor repair, but when it returned fixed the machine wouldn't work.
    I found out that alarms a & b were caused due to the +24 volts power supply being zeroed because of a short circuit between the footswitch wiring and ground.
    So I focused on the 3rd one and after some reading I figured out this E-stop alarm was caused by the machine's drives system, it was not the general E-stop machine alarm wich has another code (number) and is caused by the lack of continuity in the E-stop string.
    The #33 alarm was present because somebody, at some moment, took off a piece named Terminator (or final connector) from the spindle drive and forgot to put it back, so we ordered a new piece with MEAU, rechecked all the rotary switches in the drives configuration and everything got back on track.
    I decided to upload a video showing that service, hoping it will be used as reference/help by somebody out there, there are some pictures here also.
    [ame="http://www.youtube.com/watch?v=vmsnCstUe0U"]YouTube- SOLVED... Mazak QTN10/QT20[/ame]
    Attached Thumbnails Attached Thumbnails QT20.jpg   Terminator.JPG   Terminator tag.JPG
  1. Mazatrol T-1 QT20 ?'s Please help
    By halfafinger in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-02-2012, 08:54 AM
  2. SOLVED...Mazak VQC-20/40B Spindle drive issue
    By SINUMERIKO in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-02-2010, 08:29 PM
  3. Mazak QT20/hp
    By Rcky123 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-05-2008, 05:26 PM
  4. Mazak alarms strike again
    By trademarkmachin in forum DNC Problems and Solutions
    Last Post: 09-02-2007, 09:05 AM
  5. Mazak T1 Alarms
    By mbpp in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-21-2007, 05:27 AM
