586,384 active members*
3,741 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal 4020 Milling Spindle Problem
    Sep 2009
    75
    Hey guys, last couple of days my fadal has been acting up. I would turn on spindle only to hear some weird noises coming from it then the spindle would overload on the gauges. Any ideas what could be happening? i double checked the spindle oil, about halfway full. Perhaps the oil isn't getting to the spindle or the lines may be clogged? Currently, the spindle wont start anymore at all. It was able to run a little with noise but now nothing. Almost sounded like dry bearings or something, but then again i could be wrong.
    Had one other question, about the oil filter on the back of the machine. There are two connections on top of the filter, on my machine they are both connected to each other. Is this correct? or has someone made a mistake here?
    Any suggestions?
    Thanks in advance! (if pictures are required, i will post them. Just mention what you would like a picture of)
    Feb 2008
    547
    Free hand turn the spindle with the power off. If you still hear the noise... then it's most likely mechanical i.e. bearing, Spindle belt ect.. Noise only with the power on is generally electrical or electrical mechanical. i.e loose encoder, wires, or board. Pegging the load meter...maybe a motor driver problem or connection to same??
    Any error messages? Burned insulation smells? Other thoughts, shift idler bearings... How old is the machine?
    Steve
    Sep 2009
    181
    I sent you a message...I can help you out over the phone if you can send me your phone number.
    Need help with your Fadal? Send me a message or visit www.TheFadalParts.com. We have over 25 years of experience at Fadal and offer FREE TECHNICAL SUPPORT OVER THE PHONE!
  1. 4th Axis for Fadal 4020
    By Fudd in forum Fadal
    Last Post: 07-23-2012, 09:49 PM
  2. FADAL VMC 4020
    By dmac88 in forum Fadal
    Last Post: 05-18-2009, 08:45 PM
  3. How do I tell the age of a FADAL 4020?
    By Rickady in forum Fadal
    Last Post: 07-10-2007, 12:02 PM
  4. Fadal 4020 For Sale
    By ltmquik in forum Fadal
    Last Post: 05-18-2007, 03:44 AM
  5. Fadal 4020 resurrection......
    By jnc in forum Fadal
    Last Post: 06-30-2004, 06:22 PM
