i've been running my IH for a while now and it seems like the x and y are doing fine. the z on the other hand is giving me some fits. i had tuned the axes by ear initally and they seemed to work ok. i recently went back and tuned with a scope and tightened things up.
my mach settings are
x acceleration 9 top speed 120
y acceleration 9 top speed 120
z acceleration 7 top speed 100
on my geckos i have the limits on x and y set to 75% and the z limit is set to 100%.
the damp and gain for the z axis i had to reset really low in order to not get any oscillation when sitting idle. then when i moved i had to lower it some more. not really a problem, or so i thought. i finally got it to a position where it would move quietly on the z axis and i thought i was good. went to run a program and the z axis faulted. (i have a built the circuit specified in the gecko manual with 3 leds and 3 reset switches. this way i know what faults and it also triggers an e stop so the whole machine stops when a fault occurs.) anyway, i reset the fault, rehomed and re ran the program. almost at the same spot in the program, i smelled a plastic burning smell and shut the machine down. the smell seemed to be coming from the z axis motor.
so now i'm back to square one on figuring out where my problem lies. the program that the z motor got really hot running was a simple side milling application where it would hold position then step down in .075" increments. so there is clearly something going on here. i am starting to wonder if the drive itself isn't bad? tomorrow i will be adding capacitors to the encoder inputs, as well as a capacitor across the power input to the geckos. other than that i'm kind of at a loss for why this is happening.
