586,700 active members*
2,634 visitors online*
    Mar 2005
    21
    Using G28/G30 Home commands for THC
    Hi Guys,
    G30 is supposed to be a "hard home" which moves the machine until the home switches trigger. It doesn't do that. It does do it when you press the "HOME" button in Manual Mode, so how do I access the routine the button executes? Any ideas?
    I want to use that function to create a poor-man's torch height controller (THC) and home the Z-axis between cuts, maybe even between each move.
    Thor
    Mar 2005
    Could use G38.2 to probe instead?
    You could hook your height/home switch to the probe input. The manual says it will set variables 5061 through 5066 to the coordinates of the contact point. You could then use 5063, the Z value, to recalculate your offset.
    Something like
    G38.2 Z-1
    G10 P1 Z[#5223 + #5063]
    Variable 5223 should be the Z offset for coordinate system 1.
    I've never actually used the probe, but it seems it may do what you need.
  1. Limit and home switches EMC and Mach2?
    By ESjaavik in forum LinuxCNC (formerly EMC2)
    Last Post: 09-29-2008, 04:39 PM
  2. How do you hook up limit and home switches?
    By cncadmin in forum DeskCNC Controller Board
    Last Post: 09-23-2007, 09:34 PM
  3. mach2 home switches
    By kong in forum Mach Software (ArtSoft software)
    Last Post: 11-27-2004, 03:09 PM
  4. The relationship of limit switches to home switches.
    By MikeAber in forum CNC Machine Related Electronics
    Last Post: 11-04-2004, 08:28 PM
  5. Limit switches and home switches
    By viktorcnc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-03-2004, 12:11 PM
