587,072 active members*
3,035 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > Seeking Advice - Deep Bore Machining & Finishing
    We are working on a cylinder that has a deep step bore (sketch attached).
    Please take a look at the aketch and advice on the following:[*]Can this item be best made on a VMC or a Turning Center (we do not have a gun-drill)?[*]What is the process that you suggest we follow?[*]What are the tools that you recommend we use?[*]How can the specified surface finish of Ra 0.6 be achieved?
    Any advice on the above will be highly appreciated.
    Thanks!
    Prasad
    Mar 2006
    2712
    You could drill & bore undersized then finish with a Mapal or Cogsdill reamer. That would provide good size control. These reamers also have pads on them that burnish the surface to a smooth finish.
    Depends on how malleable the material is.
    Dick Z
    DZASTR
    Hello Dick,
    Thanks for your advice!
    Will get in touch with Mapal/Cogsdill for their reamers
    Just FYI - We tried drilling + bore lapping but didn't work. As for burnishing, we were told that the l/d ratio was too high for a regular burnishing tool
  1. Seeking advice on GE/Fuji AF-300 VFD
    By jimjovan in forum Phase Converters
    Last Post: 04-05-2010, 02:21 AM
  2. Prospective Machinist Seeking Advice
    By Septimius in forum Community Club House
    Last Post: 02-26-2010, 07:57 PM
  3. SEEKING ADVICE
    By kling8 in forum WoodWorking Topics
    Last Post: 11-19-2009, 09:19 AM
  4. Macro Programming for Taper Bore machining
    By yaji63 in forum G-Code Programing
    Last Post: 05-22-2008, 04:26 AM
  5. Can an X1 bore a deep 70mm dia hole in Al?
    By digits in forum Benchtop Machines
    Last Post: 03-04-2007, 04:24 PM
