586,655 active members*
3,354 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Newbie, How you decide Moving Gantry or Table ?
    Feb 2005
    234
    How you decide ?
    correct me if I'm wrong.
    if the material to be cut is heavier(moving table) then it should be moving gantry. wrong ?
    rud
    May 2003
    325
    rud:
    that is correct: in general if the weight of the material plus table is greater than the weight of the gantry, then move the gantry.
    other factors to consider are machine stiffness and desired accuracy.
    robotic regards,
    Tom
    “Here are all kinds of employers wanting all sorts of servants,
    and all sorts of servants wanting all kinds of employers,
    and they never seem to come together.”
    - - Charles Dickens, English writer
    Aug 2003
    143
    Rud:
    The trade-off is that for a given amount of effort and expense, the moving table machine will be more rigid and more accurate; however for the same effort and expense the moving gantry machine will take up far less space. So, it boils down to accuracy and rigidity versus space.
    Patrick;
    The Sober Pollock
    Feb 2005
    234
    ok thanks guys,
    just to make sure... moving table is more accurate ?
    and I think I can use 1 motor for moving table, compare if I'm using moving gantry may be use 2 motor.
    thanks guys
    i'm trying to make one, collecting parts cheap... take times.
    Nov 2004
    260
    Quote Originally Posted by Calico
    How you decide ?
    rud
    You are correct, sort of.
    The part most prone to changes in weight should be stationary so the
    moving masses are more consistant for accuracy.
    A lighter weight can be accelerated more rapidly for performance.
    Machine Parts move towards each other, it is irrelevant wich one
    actually moves the important thing is the design and support of the
    elements that guide the transitions and there spacing towards each
    other that have most impact on stiffness and accuracy.
    Of course Floor space may also be something to consider.
    Feb 2005
    234
    Now what's the basic formula to choose how big the ball screw and how big the motor ? for moving table ?
  1. Moving Gantry Or Moving Table
    By DDM in forum DIY CNC Router Table Machines
    Last Post: 04-02-2017, 11:03 PM
  2. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  3. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  4. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
  5. Moveable Gantry or Table?
    By barkster in forum DIY CNC Router Table Machines
    Last Post: 11-09-2004, 02:26 AM
