586,956 active members*
3,085 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal external servo control or Haas external servo control
Results 1 to 13 of 13
    Apr 2005
    1194
    How do these integrate into the machine? We are looking at adding a Haas external servo control unit for a B axis in a different type of application and I need to know if this will work with a -4 system. Now I am assuming you just need the 1010-4 board and a cable with the extra cable plug for the external servo control. Will this work that way? Neal?
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Sep 2009
    181
    Fadal has a few "M" function outputs, but in order to get that you need to add PCB-0008 (1050-3) to slot 16 (between 1040 and clock card). I have one available if you need it.
    Have a good holiday!
    Need help with your Fadal? Send me a message or visit www.TheFadalParts.com. We have over 25 years of experience at Fadal and offer FREE TECHNICAL SUPPORT OVER THE PHONE!
    Jul 2009
    317
    The Hass indexer needs a M function Board, and a cable connected to the motherboard.
    (4 wires).
    900
    Carbidecraters--
    Iess55 and Denmar are right on the money. You will need the 1050 M function board. and Yes it should work.
    Neal
    Apr 2005
    1194
    So from what I gather I will need the 1010-4 axis controller card and the 1050-3 M code card and to check the pinout. This is for adding a 5th axis to a already 4 axis machine and we will still need to keep the rs232 open. What wiring part number for the 5th axis cable connect ect? This is a -3 88HS DC system.
    900
    An Indexer doe NOT require a 1010 card. The rotary motors is controlled by the external control box and not the VMC control.
    It will be interesting to see how you syncronize a 4th and a 5th indexer!!
    Neal
    Apr 2005
    1194
    My issue is that I dont want to have to buy an extra amp, amp chassis, controller card, wiring for adding a B axis while an A is present. You would think these would be the best buck option for using a full B axis without breaking the bank on "in the back cabinet electronics". Unless I am wrong and you can only get indexing out of these and not full axis capability.
    Jan 2004
    3154
    There are a few extra M functions available (on my -4 anyway (63 and 64 maybe?).
    I don't know what output is given from them Likely low voltage at milliamp). It wouldnt take much for an electrician to switch a relay giving whatever power out needed to signal the stand alone rotary.
    If it is a constant index, you could wire a trigger switch and when index is needed just move the/a toolholder over to make the switch contact.
    Maybe I am being too simplistic.
    www.integratedmechanical.ca
    Feb 2008
    86
    Pardon my ignorance. Are these programmable rotary tables basically akin to electronic dividing tables that receive limited inputs, ie a single pulse telling it only to index to the next programmed location. I would guess there is a reset signal as well? Am I correct in thinking that the Fadal would need an additional driver board ect set up in the same manor as the 4th axis thats already there in order to be a fully functional 5th axis machine?
    Adding this 1050 M function board is nothing more than an on/off relay similar to what would manage machine coolant, ect. Thanks. Dave
    Apr 2005
    1194
    From what I understand the stand alone servo control has the amp and the drive in it and all you need to do is integrate it into a 5th axis plug and it does the rest.
    Feb 2008
    86
    So the 5th axis plug is giving signals more complex than a simple pulse to go? Thanks. Dave
    Oct 2007
    6
    Coming into this rather late, I can say a few things about the Fadal Indexer having assembled them and provided technical support at the factory.
    The control box does have it's own amplifier. The connector is not the same as the DC 4th axis connector. It is fully stand alone usable, or M-function controllable from the CNC. On a fadal machine there is a built in DNC index macro, #INDEX, that will send the index commands from the CNC to the indexer via RS-232, which allows for tighter integration of the index control with the CNC. Particularly in the event of a fault condition, the indexer can send an e-stop command to the CNC which could prevent crashes. With th #index macro the m-function card is not needed.
    ex:
    #INDEX "G1 F150. A90."
    will move the indexer 90 deg at 150 deg/min through the RS-232 cable without the use of an M-Function card.
    Oct 2007
    6
    Quote Originally Posted by Neal View Post
    An Indexer does NOT require a 1010 card. The rotary motors is controlled by the external control box and not the VMC control.
    Neal
    Neal,
    There was one special TR-65 (trunion 4th&5th axis - for those not familiar with the Fadal rotary models) used at Westec that was configured to be run with two indexer controls for a demonstration. A special cable was made to run each indexer off the finish signal of the other.
    It would be impossible to fully synchronise multiple Fadal indexers via m-function or RS-232.
  1. Haas dprint to external computer???
    By mt92 in forum Haas Mills
    Last Post: 09-01-2009, 06:23 AM
  2. Control Mach3 with external VB.NET program
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 12-30-2008, 04:46 PM
  3. How to control 18,5 KW DC-servo?
    By Jonne in forum Servo Motors / Drives
    Last Post: 11-06-2007, 10:08 PM
  4. Haas 4th axis external drive
    By tecko in forum Haas Mills
    Last Post: 06-07-2007, 10:23 PM
  5. haas servo control
    By heartlnd in forum Haas Mills
    Last Post: 02-11-2007, 01:04 AM
