586,354 active members*
3,078 visitors online*
    Dec 2009
    12
    Networking Fusion640
    Hello,
    I need to network my Fusion controls to a central server and have some questions. At my facility we need to store all programs on a designated server folder and pull programs as needed into our Mazaks. Only one program allowed in each machine at all times (current part running on machine).
    I believe I can do this my either using the HD I/O or the DNC I/O but not sure how to map the network share folder to the machine.
    Any info would be appreciated,
    Philip
    Dec 2007
    300
    Smile
    Most M640 controls are Win95 based and networking is simple. Any IT dept can set up your machines. Share the MC_Backup\Other folder on the machine side and you can drag and drop programs using your network. Use HD-I/O to transfer the prograns to and from the machine main memory. Use CAPS only and use no spaces in the folder name or the machine will not allow you to use it for HD-I/O file transfer. Since Win95 does not support wireless networking you will have to hard wire it. (there are wireless adaptors but I have not seen one works well with a M640) Hope this helps, good luck.
  1. Networking of CNC machines
    By Klaus in forum Uncategorised CAM Discussion
    Last Post: 06-22-2011, 06:25 PM
  2. networking a2100
    By jszorady in forum Cincinnati CNC
    Last Post: 09-18-2009, 01:19 PM
  3. Centroid Networking
    By slucas_clmach in forum Controller & Computer Solutions
    Last Post: 08-15-2008, 01:02 AM
  4. Networking Centurion 7
    By Jaxmachine in forum Milltronics
    Last Post: 07-07-2008, 05:01 PM
  5. Dnc Networking
    By brtlatjgt in forum DNC Problems and Solutions
    Last Post: 08-26-2006, 05:32 AM
