586,525 active members*
3,288 visitors online*
    vwdevotee Guest
    GRex replacement?
    Hi. It's been a while since I've been able to play with anything CNC (grad school kind of sucked that way). In the mean time, it looks like the GRex has come out of production. Is there a replacement in the works for it? I'd wanted to use a GRex and Mach 3 for my drive system, so is there an different elegant solution like that anymore? Or am I going to have to have parellel breakout and IO boards?
    Peace!
    Sep 2007
    200
    look for the smoothstepper
    by some dude, it uses usb and could really be your solution
    The Smoothstepper connects to your PC via USB, but still uses parallel breakout boards connected to it. www.warp9td.com
    The G100 was never fully integrated with Mach3, and very few are still using it. The Smoothstepper plugin for Mach3 is still not 100% complete, but there are a lot of people using it.
    There are several non parallel port Mach3 options available. Galil, DSPMC, KFlop...
    http://www.machsupport.com/plugins.php
  1. Replies: 2
    Last Post: 07-09-2008, 11:24 PM
  2. grex
    By bbrown2005 in forum G-REX
    Last Post: 03-18-2007, 02:38 PM
  3. So what CAN GREX do right now?
    By PeteZ28 in forum Gecko Drives
    Last Post: 03-06-2007, 03:17 PM
  4. Grex and AB
    By efrem in forum G-REX
    Last Post: 07-16-2006, 04:29 PM
  5. Grex 100
    By planeflier in forum G-REX
    Last Post: 05-12-2006, 10:18 PM
