Hi all. I've a question regarding electronic edge finders. Do you use them with the spindle running or spindle off? The Tormach video on edge finders shows the electronic edge finder being used with the spindle turning. The instructions that I've been able to find (few and far between) say to use them with the spindle off. On or off? What say you?
I've using the edge finder with the spindle off but the one I have seems to have significant run out (.005) so one or two of the six lights will come on and the others stay off. Turning the spindle manually will cause the lights to on/off depending on the run out situation. I can move the table until all lights are solid but am not sure this would be correct. Should I set zero at the point where the first lights come on or where all lights are on solid? I'm still trying to figure out where the run out is being introduced. The spindle seems fine. The problem appears to be with either the collet/tool holder or the edge finder itself. I've tried two edge finders with the same/similar results.
Thanks,
Mark
