586,377 active members*
2,644 visitors online*
Page 1 of 3 123
Results 1 to 20 of 57
    Nov 2009
    28
    Grizzly G0602 10x22 Lathe Conversion
    Hello Everyone -
    I am new to this forum, but after looking around I decided to convert a lathe to cnc control. I need a small lathe for semi-production work, so I choose a Grizzly G0602 lathe to convert. My plans are to convert it to ball screws, three phase variable speed spindle, and an automatic tool changer turret. Mach3 is what I am going to use to control it all.
    Here are some pictures of the new lathe:
    Attached Thumbnails Attached Thumbnails HPIM0942.jpg   HPIM0943.jpg   HPIM0944.jpg
    Nov 2009
    28
    Electronics I am using:
    Xylotex Drive Board
    (2) 425 oz.in. Nema 23 Stepper Motors
    PMDX-122 Break-Out Board
    PMDX-171 Hall Effect Sensor (for spindle index)
    CNC4PC C6 Variable speed control
    Fuji AF-300 Mini Variable Frequency Drive
    Dayton 3 phase Motor
    I got everything wired up and tested on the bench today. It all seems to work good. Next is mounting the motor and waiting for my ball screws to come in
    Attached Thumbnails Attached Thumbnails HPIM0945.jpg   HPIM0960.jpg   HPIM0971.jpg   HPIM0949.jpg
    Aug 2006
    289
    Looks like you are already off to a great start... Those are some nice quality parts and a great machine choice to boot. Good luck with everything and thanks for posting!
    Nov 2009
    28
    Spindle speed question -
    Today I installed the 3 phase motor, and started to calibrate the spindle index signal. The signal is within 25 rpm of the called for rpm from Mach3 - Does anybody know if this is close enough for accurate cnc threading?
    My ball screws came in today, so hopefully I will get those installed soon.
    Work has started on the turret changer based on the design posted elsewhere on this forum. I am using a hirth type of coupler instead of dowels however. Enclosed pics are of the progress.
    Attached Thumbnails Attached Thumbnails HPIM0970.jpg   HPIM0975.jpg   HPIM0982.jpg   HPIM0983.jpg
    Sep 2006
    1738
    Yes, I like this thread already! Keep it coming!!!!
    Mar 2004
    1306
    Nice start. I have been eyeing up once of these lathes also. Can you fit the Z motor within that threading gearbox housing?
    What space is available under the cross slide for a backlash free X axis ball nut? On my 7X1 2conversion, I have a little Roton ball screw for X, but haven't installed it cause I'd need a second nut and anti backlash widgit, and dont have space for them.
    The commanded RPM is not used for threading in Mach 3 (or EMC, or TCNC), and would not be accurate enough for threading with these low powered machines.
    For threading, Mach will read the spindle index pulse, and thus know the actual RPM. It then adjusts the the Z axis speed each time the indexer pulses to maintain sync .
    You can increase the resolution by providing multiple pulses per rotation, as long as one pulse is twice as long as the others, and a minimum pulse width is maintained, then Mach works out for itself how many pulses per rev it is getting.
    Mach has a speed correction (look up table ) function where you tell it the actual speed verses commanded speed for four speeds per pulley setting. Say 200 RPM commanded gives 220, Mach then interprets an S200 like a S180 so that the actual speed is set about 200. It interpolates within the speed range.
    Mark
    Mar 2008
    3655
    Hi Steelpolish. Welcome to the Zone!
    Congratulations on choosing a good lathe. You seem to have a lot to contribute, and I'm looking forward to following your build.
    I have one reservation though--Your choice of driver/motors. The Xylotex will not hold up to any kind of production use, and the 91V 425s are seriously underpowered at 24V. My choice would have been G540 (Which has the C6 function & charge pump built-in and is unkillable), Keling 381s and 48V PSU.
    When the Xylotex dies, get the G540. That and a 48V PSU will allow your 425s to work a little better.
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Nov 2009
    28
    RotarySMP
    There is not enough room in the gearcase housing to mount a stepper motor unless you do quite a bit of modification inside of it. You would have to shave off the center casting that hold the gear shafts, and bore into the casting about 1/4 of an inch to fit the motor.
    The space under the x cross slide is 1.16" wide x 1.08" high. I am planning on shaving a bit from my ballnut to fit it in.
    My question on the spindle index is its bouncing around a little bit. When I command it to spin at say 750 rpm, the actual speed will show 745 - 760 and bounce between those numbers a bit. It will never at any speed show a single constant number. Is this normal, or should it show a constant number all of the time?
    Mar 2004
    1306
    Thanks for the reply on the gearbox housing and X ball nut space. What ball screws have you chosen?
    I use Turbocnc, any my knowledge of Mach is theoretic, as I have been considering changing to it.
    Having RPM fluctuations within a 2% band does not sound to me like it is a problem. It will depend on what you are trying to make, but I doubt that a <2% error on a thread will be noticeable for most practical applications.
    If you try to make a 4 foot long lead screw for an telescope mirror polishing machine, then it is probably unacceptable.
    Mark
    Nov 2009
    28
    Crevice Reamer
    Yes, I am a bit worried about the quality of the Xylotex driver. I might be switching to some 350 oz servo motors driven by Gecko G320's. I have two other mills using steppers, and I am liking the idea of a closed feedback setup using encoders for this lathe. We shall see........
    Nov 2009
    28
    I am using the 20mm ballscrew for the z axis, and the 16mm for the x axis purchased from homeshopcnc.com. They seem to be good quality.
    I was hoping the threading will be accurate enough. My main threading is 3/4 x 10 tpi, which is a pretty forgiving pitch size.
    A telescope mirror polishing machine? You never know...... LOL!
    Mar 2004
    1306
    I like the work you are doing on that turret. Keep the great photos coming.
    Mark
    Nov 2009
    28
    Update
    Finally getting time to work on this again. I finished machining the automatic turret base, and hopefully tomorrow I will finish the piston and the rest of the components for the turret.
    Also, I have changed my electronics a bit. Instead of the Xylotex board and power supply, I am going to use the Gecko G203V drivers, and a nice 48 volt power supply from Antek. All of these components should be able to fit in my computor case I have choosen for this project. I have seen other people install thier cnc drivers and components inside of a computor case - does anyone know if this ever causes an interference problem?
    Pics enclosed are of the turret base.
    Attached Thumbnails Attached Thumbnails HPIM0989.jpg   HPIM0990.jpg   HPIM0991.jpg
    Sep 2006
    122
    You can grab one of these
    http://www.factorymation.com/s.nl/it.A/id.4205/.f
    or something close here
    http://www.factorymation.com/s.nl/sc.2/category.4845/.f
    that will be a better choice for enclosure. Get the backing plate that goes with it.
    I am running the G0602 - great machine for the money. I'll be watching this thread also !!
    [ame="http://www.youtube.com/watch?v=_hM5ks62_vY&feature=related"]YouTube- G0602 5T Cut.wmv[/ame]
    Mike
    MetalHead - http://www.mechmate.com
    Nov 2009
    28
    Update 12/22/09
    Today I received my Gecko drives and new power supply. I also hooked up the Z axis - it spins smooth! Work is almost completed on the automatic turret.
    Sep 2006
    1738
    Yes! Very cool
    Nov 2009
    28
    Update 12/26
    Today was a productive day finally. I was able to wire up all the electronics in an extra computor case I had laying around. Everything is hooked up and working correctly (first time to, imagine that!). I am amazed at how fast and how much smoother the geckos and new power supply run the steppers. Way better than the Xylotex board. If anyone needs a brand new 3 axis Xylotex board and power supply, pm me and will sell it much cheaper than Xylotex (like almost half off). Work on the turret is almost finished, but its been so cold out here in Oregon, I decided to insulate and drywall my shop, so no work can be done until thats finished. Hopefully next week I can resume that.
    Say, if anyone was wondering what we do, our website is: www.customholesaw.com
    Nov 2009
    28
    Question Idea
    I have an idea I want to run by to see if anyone has an opinion:
    I have a manual lathe, and the chips are always gumming up the bed slides. What if I mounted my Grizzly at a 45 degree angle, making it a slant bed lathe? I am planning to enclose the lathe, and install a coolent pump, so mounting it at an angle would be simple if I am building a base for it anyway. Pros or cons?
    Nov 2009
    28
    No one has any opinions on my slantbed idea?
    At any rate, my shop is now completed so its back to work on this project. The automatic turret is almost complete, I just have to assemble it and test it. Does anyone know how to write macros for a toolchange?
    12
    How are you planning to rotate the lathe,
    I can imagine that its a bit fiddly to load a workpiece and see at what you're doing if you rotate the lathe away from where you're standing (so you're standing at the higher side of the lathe), and rotating the other side will cause al lot of chips heading towards your tool.
    perhaps it's possible to rotate the lathe towards you, like a normal cnc lathe, and mount the tool holder at the other side of the crossslide?
    Very interesting idea, don't know if the x axis will like it though
Page 1 of 3 123
  1. Grizzly G0602 10" x 22" Lathe Conversion
    By derekbackus in forum Vertical Mill, Lathe Project Log
    Last Post: 01-29-2019, 09:29 PM
  2. New Grizzly G0602 10x20 Lathe
    By twehr in forum Uncategorised MetalWorking Machines
    Last Post: 02-09-2013, 05:15 AM
  3. Grizzly 10x22 lathe, and X3 CNC conversion build log
    By TacPyro in forum Benchtop Machines
    Last Post: 05-06-2009, 06:30 AM
  4. G0602 Lathe conversion
    By SmoggyTurnip in forum Benchtop Machines
    Last Post: 03-06-2009, 03:54 AM
  5. New G0602 10x22 cuts a taper
    By rwskinner in forum Mini Lathe
    Last Post: 10-31-2008, 11:34 PM
