Originally Posted by
zax15uk
I would suggest you already have the correct tool for your varied materials.
To cut the metals with a CO2 laser would require several hundred to multiple kilowatts of power. The wood and acetal would be easier, an 80W would be sufficient.
Even accepting the above, you would still need to redesign the machine (possibly modify the chassis) and add mirrors/optics. The Z-axis would be required to focus the beam by moving the lens up/down.
Yes, Mach3 would work - it can switch the laser using one of the outputs and adjust power with PWM or an analog voltage convertor.
Zax.
