586,104 active members*
3,427 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Mach3/Gecko G540 setup questions
Results 1 to 8 of 8
    May 2009
    264
    Hi Everyone,
    I have some setup questions....as a total noob....
    I've got the Rev3 G540 and the latest stable Mach 3 installed. I used the XML file supplied.
    When I hit Page up/down nothing happens even though I have a stepper plugged into the ZAxis port on the unit. If I hit right or left arrow the stepper moves but it moves in only one direction no matter the key hit.
    No other axis will take any commands.....
    There are no faults on the G540 or in Mach 3.
    Could there be a problem with my Parallel cable? I double checked the motor pins for step and direction and they are as stated in the G540 manual.
    Any help would be great!
    May 2009
    264
    Anybody out there that can help?
    Feb 2007
    4553
    Post
    Mlabruyere,
    There is a good chance you are using a null cable "laplink" by mistake.
    You need a straight through cable.
    Check it end to end with a VOM.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    May 2009
    264
    Thanks Jeff, I think you are right. I have another cable but it's male female....so I tried to make a gender changer. This cable was used on my easy-cnc machine so I know it's a straight through. The gender changer I made didn't work....crud.
    I ordered a real gender changer (Belken). Should have it tomorrow. This will take the cable out of the equation.
    Matthew
    Feb 2007
    4553
    Post
    Matthew,
    Fry's is not that far away,
    http://www.frys.com/isp/sanmarcos.html
    Please keep me posted on your progress.
    Jeff...
    Nov 2009
    159
    -edit...error
    Now featuring Plasmaland online
    May 2009
    264
    PROBLEM SOLVED
    OK.....I got a new straight through cable (male male) and a gender changer for my other cable.
    I used the gender changer on my cable I knew to be good and all the axis started to work except the "Y". The "Y" axis would stall and move in one direction then suddenly change direction without a new input.
    I then tried the new cable and again everything but the "Y" worked.....frick.
    So eliminated the cable as the problem. Software is setup correct......
    :idea: Opened the DB9 housing and looky there....a solder joint failed.
    Soldered the wire back and everything works! :wee:
    Feb 2007
    4553
    Matthew,
    Happy to hear you are on back on track.
    Jeff...
  1. Gecko G540
    By rotger in forum Servo Motors / Drives
    Last Post: 06-02-2009, 06:43 PM
  2. gecko g540
    By Teyber12 in forum Benchtop Machines
    Last Post: 05-31-2009, 08:23 PM
  3. NO movement, Any suggestions for my gecko 201 and Mach3 setup?
    By journeyonline in forum Machines running Mach Software
    Last Post: 11-15-2007, 10:45 PM
  4. Mach3 and servo motors Setup Questions!!
    By happytriger2000 in forum Servo Motors / Drives
    Last Post: 09-01-2007, 05:59 AM
  5. More Mach3 Setup Questions
    By bill south in forum Mach Mill
    Last Post: 05-08-2006, 04:10 PM
