586,547 active members*
3,179 visitors online*
Results 1 to 8 of 8
    Mar 2009
    32
    Cool Electrocraft PMDC servo ID ? Plz !
    Hello all !
    I need help !
    I put my hands on a Used but in good condition Electrocraft PMDC servo motor from Al the Man ... well Now I want to power it up !
    I have eyeballed this product ! from KB ! and was wondering if it could do the trick ??
    Here is my Servo ID Plate !
    it very plain !!! and any help Id this motor would be welcome...
    as I need to find the HP this baby can deliver !
    it comes with a Tach ! so I guess this will feed Speed feedback to the speed controler ? I'm new to this ! but I'm willing to play !!!
    I found an Info sheet from Electrocraft Legacy Catalogue and was wondering if it could be the one for my Motor ? it's for a G700 series
    Let me know !!!
    Norm
    out !
    Feb 2007
    4553
    Norm,
    Why not ask Al? He knows these like the back of his hand.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    24223
    I think I mentioned this has a terminal voltage of around 60vdc, IIRC.
    I found this out by empirical test.
    The KB should run it OK, but you will have to restrict it from max output, put a resistor in series with the pot or method used to control the speed in order it does not over speed on full 90vdc, I would not run it over 2500~3000 rpm to be on the safe side.
    Unfortunately I believe the plate info is OEM part numbers which makes it difficult to pin down exact specs.
    Al.
    Mar 2009
    5
    I am trying to get a print for you for this motor. I think Al is right that this motor is designed to run at only 60VDC. It will run with a 90VDC drive but it will eventually pit the commutator on the armature.
    I'll let you know what I come up with.
    Email me with any questions
    Rob Kerber
    VP/GM Motion
    ElectroCraft
    [email protected]
    Mar 2009
    32
    Thanks Guys....
    So... I am not too far off on my Driver selection...
    I'll try to find one... near 70 or 80V and look for Big Resistors....
    And another question ! Under Electrical Data in the Catalogue image...
    under A and B what is the meaning of those letters ?
    for each variant.... has 2 columns A + B ?
    and the Tachometers... Do I have to do a Imperial Measurement on the output of the tach...or can I measure the impedance ! and Gestimate ?
    and I'll try not to fry the motor...
    Al would not be impress ! :argue:
    (flame2)
    and thank you for looking for that Data Sheet for this Motor....
    Take care ALL ~
    Norm
    OUT !
    24223
    The Tach output is a generated DC voltage proportional to rpm, usually indicated in v/1000rpm.
    You can easily measure this at a given speed.
    Don't put any resistors in series with the motor, the one I indicated would go in series on the high end of a control potentiometer for example.
    Also there are quite a few A-M-C servo controllers on ebay that can be run in the velocity mode for spindles.
    Al.
    Mar 2009
    32
    Thank you AL !
    I see your point ! about the Tach ! and about the Resistor... on the Pot !
    what about the Horse Power Resistor... ??? on that KB Drive ?
    They come in all Flavours...
    the A M C drivers... well !!! are out of my League ! 300$ ouchie !
    I don't need anything fancy !!! but controlabe via Mach 3 !!! with analogue ref. voltage from the Tach as a Spindle Speed Control Accel and Decel !
    are Breaking Resistors required ? or a controlled Decel time good enough ?
    Sorry for the Many questions but I don't want to Burn anything...
    ie. when the Servo is Free spining... and feeding EMF back into my board !
    so much to learn so little time !!!
    Norm
    out !:drowning:
    24223
    I would go with a 1/2hp value to begin with. The worst case scenario is you would go into current limiting earlier, but I don't think that will happen.
    Al.
  1. Electrocraft BRU 105 Servo drive Schematic
    By lekridge in forum Want To Buy...Need help!
    Last Post: 10-25-2019, 03:28 PM
  2. Electrocraft servo - How do they work?
    By Chris64 in forum Servo Motors / Drives
    Last Post: 10-05-2006, 04:12 PM
  3. Electrocraft Servo 0660-12-031
    By bemfarmer in forum Servo Motors / Drives
    Last Post: 09-03-2006, 11:11 PM
  4. Looking for a source for PMDC servo motors
    By bgolash in forum Servo Motors / Drives
    Last Post: 01-31-2006, 10:26 PM
