586,119 active members*
3,517 visitors online*
    Mar 2004
    60
    sub routine acramatic 950
    i got a large program that the controls segments in the memory then calls the segments to active memory as needed. my ? is can you run a sub routine with a segmented program. THe program being called is segemented. I have been getting a ENS not found error code but the ENS is at the end of the SUB ROUTINE. I think the segmented program is causing the conflict.
    Feb 2008
    586
    Very long time since I ran an Acramatic, and that was an 850SX. Post your code? I think it's format was:
    (ENS,)
    But that's how long its been.
  1. help with sub-routine programing
    By accramachine in forum G-Code Programing
    Last Post: 11-13-2009, 02:34 PM
  2. Sub Routine
    By ynnek in forum Uncategorised CAM Discussion
    Last Post: 09-18-2009, 01:01 PM
  3. program exit sub routine
    By MMTechi in forum G-Code Programing
    Last Post: 06-11-2009, 10:51 PM
  4. Activating HPCC in a sub-routine?
    By Dawson in forum Daewoo/Doosan
    Last Post: 03-18-2006, 09:04 PM
  5. 3D surface sub-routine
    By lazza in forum G-Code Programing
    Last Post: 08-30-2005, 02:58 PM
