586,903 active members*
2,671 visitors online*
Page 1 of 4 123
Results 1 to 20 of 66
    Nov 2005
    152
    My CNC pressbrake build
    I have been planning this for a long time. I just have not had the time or money to start on the project. I have changed my mind on the design many times. I think I finally have it down the way I want. for the most part it is going to look like any other C-frame style brakes with a few improvements.
    Specs:
    48" wide
    58 tons
    6" inches of ram travel
    2 axis servo backgage
    Mach 3 control with a Dynomotion motion controller for the control of the +-10V analog Parker Proportional valve.
    5hp, 2.5GPM pump.
    I will be building the entire thing including the cylinders. ( That's what I do for a living.)
    I am going to start of with building the 2 cylinders first. The cylinder are 5" bore, 3" rod, and 6" stroke.
    Pile of Parts
    Rough machining of the base heads. I will finish machine them after I weld them to the barrel.
    Pistons are next.
    Checking the threads with a Go gauge.
    Rod heads next.
    Piston rods next
    Weld prep on the barrel.
    Aug 2004
    2849
    How about including some guidance on bore versus piston size.....whatever you're using for the ring material, etc. It would help those of us that maybe thing of building our own hydraulic piston assembly.
    Paul
    Nov 2005
    152
    Quote Originally Posted by ViperTX View Post
    Paul
    On this design the piston is .018 under bore size because I am using a 1" composite wear band on the piston. The piston never touches the bore so the major is just for clearance. I am using regular lip seals also on the piston, no actual steel rings. The wear band to bore only has about .001-.002 per side clearance For oil.
    May 2005
    2502
    Very cool!
    And the material you're using for each of the components is?
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Nov 2005
    152
    Quote Originally Posted by BobWarfield View Post
    Very cool!
    Cheers,
    BW
    Barrel: ST52.3 DOM
    Piston and rod head: Nodular Iron. I will look at the grade monday when I go back to work.
    Piston rod: IHCP
    Base head: A36
    Nov 2005
    152
    I finally got some time after work tonight to work on the cylinders again. I got the ports welded on and the Id threaded. I also ordered 2650 pounds of steel for the frame. I should have it next week.
    May 2009
    107
    Very nice turning work I am watching with intrest!
    Nov 2005
    152
    I got the caps welded on the barrels and milled out a slot then drilled a few bolt holes through. I also got the wrench flats milled on the rods.
    I then went and picked up the flame cuts. I had a buddy that works at a steel place get and cut me out a bunch of 1.25" HR plate.
    May 2009
    107
    WOW, How much did that plate weigh?
    Dec 2004
    312
    from looking at that size aprox 3000 pounds
    am i correct?
    looking really good so far
    Nov 2005
    152
    The 4 pieces where about 2600lbs.
    May 2007
    111
    How about a quick sketch of what your completed press will look like. This is a very interesting thread. Thanks for sharing.
    Nov 2007
    197
    awesome project! can't wait to see how you control the valve with mach.
    we just completed a 40 ton, 2 axis hydraulic press at work using bosch / rexroth controls. would love to see how to do these types of things on a 'budget'.
    Nov 2005
    152
    Today I started milling up the frame for the brake. I got the sides almost done and started on the upper and lower beams.
    Upper beam
    Lower beam
    Dec 2009
    122
    Nice home shop equipment...LOL.
    Looking good.
    Nov 2005
    152
    I got the cylinders assembled and tested.
    Did a little bit more work to the lower beam.
    More work on the upper beam.
    Cylinder test fit.
    May 2005
    2502
    Fast progress!
    Best,
    BW
    Nov 2005
    152
    Finished drilling all the holes in the side plates.
    Finished tapping the last hole in the upper beam.
    Turned some 4340 spuds to mount the cylinders to the beam.
    Nov 2005
    152
    I did not have to work today, so I went in and made the upper and lower die holders. Hopefully tomorrow I can start assembling the whole thing.
    Nov 2005
    152
    So, today I got it mostly assembled. I had to use some good old redneck engineering to put it all together but it all worked out great. I had my dad help me out with the tractor work.
Page 1 of 4 123
  1. Yawei pressbrake type QC12Y hydraulic diagram
    By zavateandu in forum Uncategorised MetalWorking Machines
    Last Post: 08-21-2012, 01:14 PM
  2. LVD Pressbrake?
    By rszemeti in forum Uncategorised MetalWorking Machines
    Last Post: 07-15-2012, 10:57 AM
  3. delem da 65 pressbrake controller
    By gerry1969 in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2012, 05:00 PM
  4. Suggest me the best Pressbrake machine
    By gvk1985 in forum Want To Buy...Need help!
    Last Post: 03-07-2011, 03:38 AM
