586,317 active members*
3,359 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Auto dimensioning?
    Mar 2004
    564
    Talking Auto dimensioning?
    I was wondering if there was a way in ACAD to have the ordinates (X,Y) placed on the drawing as I am working? Right now, I draw first and then have to come back and select every point using the dinension tool 'ordinate'.
    Is there an easier way?
    menomana
    Nov 2003
    634
    Several companies make add-ons for Autocad that do something similar.
    Here is an example.
    http://www.strikersystems.com/ssdesign/ssdesign.pdf
    They are talking about sheet metal, but it works on any type of drawing.
    You would make your drawing, press a button and then all the ordinate dimensions are added automatically. The only downside is that it will give you alot more dimensions than you need. For example, you'll get start and end points of fillets, plus the center of the fillet.
    Its pretty quick to go back and delete out the dimensions you don't want though.
    I'm sure that there are others, this is just one solutions that I used before.
  1. Please Help ESAB AUto Path 750
    By pcasey in forum DNC Problems and Solutions
    Last Post: 10-23-2008, 10:53 AM
  2. need help with auto radius and chamfering
    By dry run in forum G-Code Programing
    Last Post: 01-30-2005, 09:52 AM
  3. Single line mode works well, Auto is not soo good??
    By Darc in forum CamSoft Products
    Last Post: 10-26-2004, 09:29 PM
  4. cut single, cut auto and cut all???
    By fastolds in forum BobCad-Cam
    Last Post: 10-06-2004, 02:15 PM
  5. Auto save as user in Mill Expert
    By HuFlungDung in forum OneCNC
    Last Post: 05-16-2003, 08:09 PM
