586,945 active members*
2,297 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > New!2200W 3000~10000RPM BLDC Motor Controller
Page 1 of 9 123
Results 1 to 20 of 241
Hybrid View
    hi everyone
    the pictures is our new products use in mini-machine,controller 2200W 3000RPM、3500RPM、5000RPM、10000RPM (Speed can be made according to the customer's requirements)
    Welcome to see and give me some suggestion
    Main function:
    ◆ Start, Stop, accelerate or decelerating, forward and reverse function
    ◆ A LCD displays real-time speed, the current state, protection
    ◆ A flow, over-voltage, overload, voltage protection function
    ◆ Motor temperature detection
    ◆ 0-10V analog speed control◆ Provide the user interface should choose function. Panel
    ◆Should provide 485 interface and TTL interface, which can be conveniently and communication
    ◆With a sudden stop machine, electric switch, protective mask open doors limit protection
    ◆Speed 400~6000rpm
    ◆Drivers can access AC110V/220V two kinds of voltage, in the same drive can be switched
    www.sangmutan.com
    [email protected]
    Nov 2009
    I accept with Main function:
    ◆Speed 400~6000rpm
    __________________
    Simulateur de credit simulation pret immobilier | Simulateur credit simulation de pret immobilier | Simulateur de credit immo
    Smile
    1100W 3500rpm AC220/110V
    1100W 6000rpm AC220/110V
    1500W 3000~6000rpm AC220/110V
    2200W 3000~6000rpm AC220/110V
    www.sangmutan.com
    [email protected]
    Smile 2200W motor and controller use in mini-machine
    Quote Originally Posted by mivuna View Post
    ◆Speed 400~6000rpm
    __________________
    hi
    This is some pictures about our motor and controller (1100W ,1500W,2200W),which kind is your needed?
    2200W 3000~6000rpm AC220/110V Used in mini-machine ,matching with Mach3
    www.sangmutan.com
    [email protected]
    if you have any question ,please send mail to me---[email protected]
    Attached Thumbnails Attached Thumbnails 2200W.jpg   2200W 3500rpm motor and contriller.jpg   2200W control.jpg   2200W controller.jpg
    IMG_0841.jpg   1100W 6000rpm.JPG   1100W 3500rpm controller.JPG   1100W(0~10V).JPG
    At present, we are developing 3 ~ 4KW motors and drives,Soon there'll be products
    zhang
    [email protected]
    www.sangmutan.com
    Quote Originally Posted by Kung fu panda View Post
    zhang
    [email protected]
    www.sangmutan.com
    2200W motor controller use in CNC milling and drilling machine
    This control system with perfect function, simple operation, capability of anti-interference, energy saving, low breakdown rate and easy maintenance which can achieve maximum torque and smoothness when at low speed.
    2200W BLDC motor and controller
    Brushless Motor and controller match with MACH3 Software in CNC-machine
    DC300 2200W 6000RPm use as Spindle motor
    www.sangmutan.com
    [email protected]--------Design and production manufacturers
    zhang
    Attached Thumbnails Attached Thumbnails brushless motor and controller.jpg   brushless motor.jpg
    Attached Files Attached Files
    Our controller use in mini-machine ---willn't been Burnt
    Our BLDC controller will not been Burnt
    zhang
    www.sangmutan.com
    [email protected]
    Splindle motor and controller made by sangmutan
    www.sangmutan.com
    [email protected]
    Sep 2006
    1738
    I don't see the prices for the Mini Mill motor/controller combo?
    Oct 2009
    80
    Did you get my email about: "92ET-BLM-300HA-SMT AC220V/110V 750W 6000RPM,12000RPM"
    Is it rated 12krpm at DC 300V and 6krpm at DC 150V?
    What is the weight and torque specs of the motor?
    Price?
    thanks
    Quote Originally Posted by SpeedsCustom View Post
    There are some old prices here to give some idea: http://www.cnczone.com/forums/showth...t=89162&page=2
    Smile
    [QUOTE=ee_t;768343]Did you get my email about: "92ET-BLM-300HA-SMT AC220V/110V 750W 6000RPM,12000RPM"
    Price?
    thanks
    Hi
    I am sorroy for delay reply,i was not in the office recently ,i got your E-mail.
    Is it rated 12krpm at DC 300V and 6krpm at DC 150V?----NO
    the speed will not lower down. the motor is the same(DC300V 750W ) , but our controller can be exchanged between AC110V/220V.
    i will send some infomation to your E-mail
    Panda
    Dec 2005
    132
    Hey Panda!
    I need a new motor for my mill I have e-mailed you.
    Quote Originally Posted by gotis View Post
    Hey Panda!
    Dear Jonas
    I have receive your e-mail ,and i think 1100W 10000rpm is not suit for you ,if you use in milling machine ,the speed is too high ,i think 6000rpm is enough if you use in cnc-machine,i will send some detail infomation about our motor and controller to you sooner
    zhang
    Dec 2005
    132
    Dear Jonas
    zhang
    I´m milling 99% Aluminium and around 2000-5000rpm, thats why I´m looking for high speeds, but if the torque is lower on the 10000 in that range than the 6000 I´ll go with that one.
    I´m using a Treadmill motor that´s rated att 2hp and power is enough but the brushes burn out too fast.
    Please see http://www.cnczone.com/forums/showthread.php?t=63184
    Smile
    Hi
    (I´m milling 99% Aluminium and around 2000-5000rpm)Brushless motor 1100W 6000rpm is enough,I am sure
    BLDC motor ,the higher efficiency,energy-saving ,higher lifespan,our motor and controller is suit for milling machine ,Use match with Mach3
    I have send E-mail to you ,please check
    zhang
    Dec 2005
    132
    Sorry no mail recieved, can you please PM instead?
    hi Jonas
    I just sent the mail to you use my another E_mail([email protected]) ,PLease check
    zhang
    [email protected]
    [email protected]
    Sep 2006
    1738
    Kung fu Panda, can you pm price for 6000 RPM motor/controller.
    Thank you,
    -Jason
    Oct 2009
    80
    Thank you,
    -Jason
    Quote + details that were sent to me. Will remove on request.
Page 1 of 9 123
  1. Bldc motor and controller is used in the mini machine
    By wang in forum News Announcements
    Last Post: 09-14-2014, 08:58 PM
  2. Open Source 3 Phase BLDC controller
    By karl1 in forum Open Source Controller Boards
    Last Post: 02-10-2009, 11:35 PM
  3. Regarding Transferfunction of BLDC Motor
    By pathamuthu in forum CNC Machine Related Electronics
    Last Post: 01-27-2009, 09:30 PM
  4. Electrocraft BLDC motor, need some spec's.
    By lucas in forum Servo Motors / Drives
    Last Post: 02-17-2008, 07:53 PM
  5. Help inspecting/repairing a BLDC motor.
    By ESjaavik in forum Servo Motors / Drives
    Last Post: 08-16-2004, 11:32 PM
