586,465 active members*
3,726 visitors online*
    Apr 2005
    236
    Question Parameter Backup
    Hallo
    How can i make a parameter backup on a OSP5000L and OSP7000L controler to a (CN0) RS232 port?
    On a M-controler is it easy, they have transmit softkey.
    rg
    <div align='center'><strike><b><!--coloro:#0000FF--><span style="color:#0000FF"><!--/coloro--><!--sizeo:5--><span style="font-size:18pt;line-height:100%"><!--/sizeo-->&#33;&#33;&#33;&#33;....JA....WIR....LERNEN....NI E....AUS....&#33;&#33;&#33;&#33;<!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc--></b></strike></div>
    Mar 2009
    1982
    yes, it's quite different for lathe. There is softkey also. You need to find it with "extend" (F8).
    Take care about parameters - these differs for parameter save/ read from part program save/read.
    On Edit mode You can try
    =DPIP<write>
    DPIP>OP CN0:IT
    and <write> <write>
    That's for lathe
    here "IT" is file name. Extension will be .TOP
  1. Parameter Backup on 0i Mate-MB
    By rbcmetalwork in forum Fanuc
    Last Post: 01-30-2010, 06:42 AM
  2. Complete backup of all
    By duenow in forum Haas Mills
    Last Post: 02-05-2009, 04:24 PM
  3. Habegger CNC 80 BACKUP
    By Aiman Ebraheem in forum Uncategorised MetalWorking Machines
    Last Post: 03-13-2008, 08:18 PM
  4. Mazak Fusion Parameter Backup
    By Mark18969 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2008, 05:42 PM
  5. Backup Script..
    By Rekd in forum Mastercam
    Last Post: 09-11-2003, 03:34 PM
