Originally Posted by
Shev
So finally here's my ?s'
1) Is what amp breaker should the mill be run off?
2) How does the mill come...I'd assume that it is in pieces and I will have o put it together. I'm hoping to drive out and pick the mill up. The wife's bro lives along the way and that way my shipping cost is $0 since it would be disguised as a family trip and the family budget would pay for it.
3) Would it be wise to epoxy granite the base & column right when I get it?
4) Should I be able to run a 3" Glacern Facemill on this mill with epoxy grante & with a 3HP VFD and not have an issue as long as I don't take too big of a cut?
Thanks in advance...
1. Ask Tommy about the breaker or wait and check the VFD documentation.
2. Mine came assembled in the crate. I had to disassemble it partially to get it in place. The one I CNC'd I bought already completely disassembled.
3. I like my epoxy granite, and the results are noticeable versus my second mill which is stock. With that said, it is not a profound difference. Things are just more solid. If I had to guess, I'd say 15-20% rigidity/vibration damping improvement. It's not hard to do an E/G fill. I spent a day prepping the base, a day filling the base, and a day filling the column.
4. I sure hope so because I just bought a 45 degree face mill from Glacern!
I don't think there will be a problem with the facemill, depending on how deep you want to cut. I don't have the Glacern to try yet, but I have an Iscar 2" with APKT inserts (90 degree shoulder) and a Lovejoy 3". Both are great performers and I regularly cut 150 thousandths. They might do more, but that seems to work out pretty nice for a roughing cut. I drop back to 30 or 40 thou to finish.
With my 3" face mill, I run 900 rpm and 32 IPM on aluminum. Those are the recommendations from my G-Wizard feeds and speeds calculator and they work very nicely.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
