586,701 active members*
2,580 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Advice needed for Mill Feed Rate
    Mar 2005
    18
    Can someone explain to me the feed rate concept for mini mills like the Sherline?
    For example, 6061 alu has SFM of 280 - how would this relate for the rpm of the lead screw? Say I was turning it by hand, how fast would I need to turn the feed for a given sized end mill?
    Jan 2004
    258
    Milling cutters need to run at a required "chip load". I run at "IPM", if your tool is a two flute end mill I would run it a .004 to .006 chip load depending on rigidity of the setup. Say your end mill is 1/2 calculated it would run at 2139 rpm at 17 to 25.5 ipm. The formulas for doing this are in the machinists hand book.
    Jun 2004
    450
    Here's some helpful formulas from a quick google search. http://www.manchestertools.com/tech/1_10.asp
    You would want the second one down, in the left column.
    Sep 2004
    77
    I have been using a Sherline 5410 for about 6 months.
    I always run it at max RPM (2500), and then I also run it at maximum feed for my setup, which is about 330mm/minute. Then I adjust depth of cut until it sounds good.
    For T6, that means I normally take between .8-1.1mm cuts for a 3/8" endmill going at 330mm/min and 2500rpm.
    I hope that helps,
    Swami
    Nov 2004
    260
    The Surface Speed and Chip loads found in the Machinist Handbock are for
    very large and rigit machinery on smaller machines you will have to derate
    the values somewhat.
    The important thing is the Chipload per tooth, each chip taken acts as a little
    Heatsink removing the heat generated durring cutting.
    It has to be of sufficient thickness to do this job a much tinner chip would
    get much hotter and start melting wich causes it to stick to the cutting edge
    and generate even more heat on consecutive cuts.
    So when derating the values in the Handbock you want to reduce the chipload
    to a value that will still provide a resonable thickness at a reduced feedrate the
    Spindle Rpm can be calculated from there.
    The most common mistake people make is to use the Surface speed found in
    the handbock and simply feed at a much slower rate to suit the ridgidity of
    there machine. This results in a very thin chip that will melt and stick.
    Reducing your Spindle speed to match your chipload is much better.
    Good Luck
  1. Need Bridgeport EZ-Track G-Codes to build post
    By soweebee in forum Bridgeport / Hardinge Mills
    Last Post: 01-28-2006, 08:10 AM
  2. Feed rate question
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 10-30-2004, 07:00 PM
  3. How can I up my feed rate ?
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-13-2004, 03:40 AM
  4. Master 5 feed rate question
    By IIRONMANN in forum Mach Software (ArtSoft software)
    Last Post: 12-29-2003, 08:25 PM
  5. feed rate issue with arcs.
    By balsaman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-26-2003, 02:25 PM
