587,006 active members*
3,168 visitors online*
    Jul 2005
    261
    oiling series 1 rigid ram
    I am about done my retrofit gutting electric drive, replace w/ geckos and using original steppers. Machine runs, moves, and is accurate. It has a bijor oiling system, which may / may not work. I know the gears spin when I apply 120v electric but thats it. I'm afraid to run too many test jobs on it without knowing its properly lubed, especially the spindle. The ways seem to be oily, the ballscrews x,y seem to be oiliy too.
    At first glance on the top of the machine, I cant seem to find anything that says "grease here ->" or "oil here ->". When the spindle runs I can hear some chatter, of course.
    Does the spindle require manual oiling or does the pump handle that? Does anyone have pics or a manual that show the oiling points on this? Thanks
    -Erich
    WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
    24223
    After some years use the metering ports at the end of each lube point can become clogged, usually the only way is to replace the metering device, each has a number stamped on it indicating the orifice number.
    Often only a couple of ports end up with lube, when the rest get clogged.
    Can't tell you if the spindle gets lubed this way however.
    Al.
    Sep 2004
    131
    series 1 oiling
    Hello Erich the main parts of the machine such as the slideways, ballscrews, that is the X, Y, and the Z axis is fed by the pump. The Bijur pump needs to run when the spindle is running and cut the spindle power if the oil level goes low as indicated by the float switch which is in the pump container and controlled by the extra 2 wires to the 120 volt pump motor power. The rest of the head spindle parts and bearings are all sealed with grease, the overflow from the Z axis ballscrew runs down over the top and the lubricates the quill, so you will eventualy see oil running out from the bottom of the quill.
    Hope this helps Cheers Colin.
    Jul 2005
    261
    Ok thanks for the replies. I hard-wired my pump to run, and it doesnt appear to raise the pressure, or overflow I dont see it seeping out anywhere. Before I use the machine I just squirt the ways down with 10w-40 oil anyway.
    Just the spindle has me a bit worried, I read in the manual its sealed grease bearings, and was checking to make sure, since obviously I wouldnt want to run this and find out I have an unusual version that needs oil in some spot thats not obvious.
    -Erich
  1. Update on tramming the rigid ram Series 1
    By swarf_rat in forum Bridgeport / Hardinge Mills
    Last Post: 03-23-2018, 10:52 PM
  2. Oiling of the ways!!
    By chipsahoy in forum Fadal
    Last Post: 09-06-2007, 12:48 PM
  3. X3: Way oiling? One shot?
    By InspirationTool in forum Syil Products
    Last Post: 01-23-2007, 01:18 AM
  4. Way oiling systems
    By Greolt in forum Benchtop Machines
    Last Post: 07-26-2006, 04:39 AM
  5. Z not oiling!!!!
    By carbidecraters in forum Fadal
    Last Post: 07-07-2005, 02:26 PM
