586,119 active members*
3,610 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > My second machine build log (aluminum, Chinese spindle, rails, screws etc.)
Results 1 to 19 of 19
    Dec 2008
    27
    I'm building new cnc machine, my second build.
    First machine was from MDF (hobby design and all... )
    I learned a lot on fist machine and here i will put build log for second machine.
    This is construction for second machine.
    More pictures you can fine on my site where it will be more detail text and pictures.
    www.mycnc.giveinfo.net
    1050
    before you proceed the linear rails for the long axis are too low - pls don't do the mistake I have already done.
    Dec 2008
    27
    Why do you think it's low ?*
    Sep 2009
    96
    Build looks fantastic so far!
    Dec 2008
    27
    Here is more pictures of machine building procces!
    Attached Thumbnails Attached Thumbnails cnc2 008.jpg   cnc4 012.jpg   cnc4 013.jpg   cnc4 014.jpg
    Apr 2008
    211
    WOW! Your machine is looking very profesional.
    I will be following your progress attentivly.I love the ball screw and rail combo .Looks like a rigid setup,you should be able to make acurate parts.
    Dec 2008
    27
    Post
    As i started with mdf machine (my first) this one now for me is unbelievable good.
    I did little measuring, and on Z axis ( measured with indicator) i can move axis to 1/10 mm (0.1 mm) and 1/100 mm Mach3 and indicator show same number,
    1050
    I hope you have seen my build - what happens with your and my setup is that as we start inchreasing the height of the gntry the whole thing begins to shudder when there is sudden change of direction.
    I am most worried taht you will face the same problem, then ou will have to reduce the speed at which you are running your router.
    pls do reconsider and do necessary changes before its too late.
    believe me - you will be much happier.
    there are a couple of Australian builds you can probably look at - http://www.cnczone.com/forums/showth...t=71219&page=3
    RGDS
    IRfan
    Jul 2008
    267
    My datacut machine shutters when I change direction. It has a 80lb gantry, so no wonder why.
    http://www.data-cut.com/router.html
    All I did was add a few cross braces and adjusted the deceleration/acceleration. The shutter is reduced and does not present an issue. Chris the builder of the original datacut says his shutters and it has not caused any kind of a problem in the 4-5 years he has been running it.
    Dec 2008
    27
    new video
    Dec 2008
    27
    This is video of testing milling rosfrai, with end mill 3mm -0.2 in Z
    Apr 2008
    384
    First of all the machine looks great.
    Secondly, to my untrained eye the sides of the gantry look very thin compared to the rest of the machine. I'm not sure if it's just me but it looks as if they will flex a bit.
    Aug 2009
    33
    I always wanted to know where you get the metal for the machine. I tried some metal manufacturers but the metal is very expensive.
    So can you give some info on where to get some aluminum supports?
    Marc
    http://www.youtube.com/MacsterTech
    Dec 2008
    27
    I got aluminum in LIPRO , it's in Slovenia.
    LIPRO.si
    yngndrw First of all the machine looks great.
    Machine is made for wood carvings, 3d and stuff. ALU is hardest material i will use. Rosfrai and other things are just me testing
    Apr 2008
    384
    Fair enough. As I said it looks great ! Good luck with it.
    Aug 2009
    33
    Quote Originally Posted by giveinfo View Post
    LIPRO.si
    I'm guessing that is not in the US..
    Thanks for the info, also if you dont mind giving some tips on my machine.
    Marc
    Dec 2008
    27
    No, that's Europe.
    Dec 2008
    27
    A axis in testing
    Hello to all, i started testing a axis on machine, this is what i got so far.
    There are more pictures and video on my site.
    Be free to comment!
    Nice job. Does that keyboard still work?
  1. Chinese ballscrews,ballnuts,blocks and rails?
    By kostas1 in forum DIY CNC Router Table Machines
    Last Post: 10-04-2009, 12:04 PM
  2. Spindle that can machine aluminum
    By Dman65 in forum DIY CNC Router Table Machines
    Last Post: 08-04-2009, 04:28 AM
  3. Build CNC machine out of aluminum?
    By jeffmorris in forum DIY CNC Router Table Machines
    Last Post: 03-24-2008, 05:06 PM
  4. Long screws and rails
    By 3Dsigns in forum Linear and Rotary Motion
    Last Post: 06-14-2007, 07:59 PM
  5. Machine Aluminum... Spindle speed and flute count
    By ngr1 in forum MetalWork Discussion
    Last Post: 01-04-2005, 06:35 AM
