586,403 active members*
2,231 visitors online*
    Jan 2009
    8
    Spindle speed control with Sherline controller
    Hello,
    This is my first post, hope someone has an idea!.
    I am running a Sherline cnc lathe with the Sherline control box and computer. I have installed Mach 3 as I found Linux Ubuntu a pain to set up. Everything is working OK but I would like to thread cut and need to control spindle speed from Mach3. Is this possible?. i.e. Does the Sherline controller have an input capabilityfor this.
    Thanks.
    Oct 2009
    118
    You would need a spindle encoder, detects speed of spindle to sync z axis.
    Here is an example, but I have no idea if it is overpriced or works good.
    http://www.cadcamcadcam.com/latheencoderkit.aspx
    Possibly this will do the same thing, not sure why they would use a stepper drive for anything else?
    Some one please comment on the use of a stepper as a spindle drive...
    http://www.sherline.com/6500pg.htm
    Jan 2009
    8
    Thanks Leggazoid,
    Good start for me.
    Dec 2005
    12
    Quote Originally Posted by leggazoid View Post
    The encoderkit cadcamcadcam is not ok for mach.
    This encoder has to many counts/rev.
    Mach can only take about 4 to 6 counts/rev.
    Oct 2009
    118
    http://www.cnc4pc.com/Store/osc/prod...roducts_id=129
    what about this index pulse card? would it work in mach3?
  1. speed control with MIDI servo controller?
    By dondeaida in forum RC Robotics and Autonomous Robots
    Last Post: 07-27-2007, 02:05 AM
  2. Sherline mill with spindle speed control
    By rozon in forum Benchtop Machines
    Last Post: 07-15-2007, 05:02 AM
  3. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
  4. Sherline Speed Control kaput
    By mikkojay in forum CNC Machine Related Electronics
    Last Post: 05-05-2006, 05:59 AM
