586,576 active members*
3,602 visitors online*
    Aug 2009
    7
    Unhappy Need advice in my project
    I was see UHU controller and was start to project "my 18F4431 PID controller + HP UHU output stage.
    All work as I expect but with one problem what I can't find from where it come.
    Irrespective which speed is of motor movement I have some erratic clip of motor in not constant period - from time to time lik "ping ,ping ping" and motor stress a couple steps +/- and go to next stress which come after unknown period. Sometime is couple stress one after one but sometime only one and so on.
    I was look at scope and I cant find any anomaly in signals.
    The output stage is identical HP UHU with IRF540N and motor is 30V "duncanmotor with gear 6.25:1 with optical encoder RE30-2-500".
    I read it in 4X mode and drive 20KHz PWM from pic on CCP1 for Locked-Antiphase.
    Any idea or help please.
    The best regards
    /Robert
    P.S. Sorry for bad English...
    Aug 2009
    7
    Talking End of problems
    No need for help I was success fix problem in config of 18F4431.
    Regards
  1. Need motor advice for a project...
    By kentrob11 in forum CNC Machine Related Electronics
    Last Post: 03-21-2008, 03:05 PM
  2. Need some advice on my project
    By sigipa in forum Mechanical Calculations/Engineering Design
    Last Post: 09-16-2007, 05:43 PM
  3. New and in need of some advice... well alot of advice!
    By GoonShoes in forum Bridgeport / Hardinge Mills
    Last Post: 05-30-2007, 01:03 PM
  4. DIY Project with MDF
    By studysession in forum DIY CNC Router Table Machines
    Last Post: 01-08-2007, 08:57 PM
  5. Need help on a project
    By ClemsonGirl in forum Uncategorised CAM Discussion
    Last Post: 01-24-2006, 10:12 PM
