586,406 active members*
2,983 visitors online*
    Jan 2008
    NUM 1040, AlphaEdit
    I’m setting up a CNC router the controller is a NUM 1040, I’m using Alphacam to write the programs so I’m using AlphaEDIT to send the files over to the machine over a Serial cable. My problem is I can’t seem to get the computer to send the files over to the machine; I set the controller up to listen to receive the file but can’t get the file over to the controller.
    I have set the Settings on the Controller and the computer up identically is this correct?
    Are there any other programs I can try to send files over to the controller?
    Any help would be appreciated.
    Quote Originally Posted by Nipper View Post
    Hi, too
    for ensure will you send me back you num controller type...?
    and a picture of the controller.
    what operating system you use on you pc......?
    may be I can help you....
    send to [email protected]
    thanks...
  1. Chick System 5 vise 1040
    By walter_58 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 04-25-2009, 05:02 AM
  2. 1040 Low Hydraulic Pressure
    By pinguS in forum Fanuc
    Last Post: 06-18-2007, 02:53 PM
