586,392 active members*
3,082 visitors online*
Results 1 to 7 of 7
    174
    timing belt instead of screw
    I wanted to use the attached design with 25mm belts on a 4x4 table. I was going to gear it 3 to 1. Could I get some pro and con on this.
    Thanks Ed
    24223
    I have used this principle, Breco Belts sell the belting and hardware for this method.
    Al.
    Dec 2007
    379
    I wanted to use belts and eventually decided to just go with rack and pinion because it was more cost effective in the end.
    If you do go with belts take a look at http://www.cnczone.com/forums/showthread.php?t=59570
    May 2007
    380
    If I build another table, I will use belts for the X and Y, and a screw for the Z. 3 full turns of the stepper for 1 inch of travel is just about right.
    John
    Quote Originally Posted by johnmac View Post
    John
    A 1" pulley will give you 3.14" of travel, so I think you'd need 9:1 gearing to get 1" of travel for 3 stepper rev's. And with larger belts, you may need larger than 1" pulleys.
    174
    I have a couple of problems in this design. Here I go. I'm using a 20mm jack shaft on x to drive pulleys on each side. So the 20mm limits me on the size of pulley I can use. I'm using at5 25mm belts. I have on the servo 14t and jack shaft 42t. This is 3 to 1. Now the smallest pulley I can go is 28t because of 20mm jack shaft. This puts me at 46.6666666mm per motor rev. That is putting me around 1.8372 inches per rev. I know on my other machine my servos at 1 inch per rev will snap a bit like it was even there on a screw up. So I'm hoping that I will still have enough torque on this new setup. I using a 150w YAG laser so no drag. But I want to add a spindle for pockets. What do you think?
    Ed
    May 2007
    380
    My suggestion on the 3:1 is based on resolution vs speed for a stepper driven table.
    John
  1. HTD timing belt pulley
    By R.thayer in forum Uncategorised CAM Discussion
    Last Post: 11-14-2013, 10:08 PM
  2. Timing belt and pulleys
    By samakthachai in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-25-2007, 05:31 AM
  3. Ball screw or Timing belt
    By skazic in forum Linear and Rotary Motion
    Last Post: 06-27-2007, 11:14 PM
  4. Ball screw, Timing belt or Rack and pinion
    By abomination in forum Linear and Rotary Motion
    Last Post: 05-01-2007, 04:14 AM
  5. Should you put grease on a timing belt?
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 04-22-2004, 02:54 PM
