586,655 active members*
2,344 visitors online*
Thread: tailstock
    May 2009
    91
    tailstock
    i got an okuma cadet with an osp 5020L controll.. i am new to this lathe and wondering how to move the tailstock and if its possible to program?
    Apr 2009
    1262
    First you need to go to parameter mode and find your chuck/tailstock screen and turn on the center work bit to make the tailstock active. You can then program the quill using M56/M55. Foot switches will become active as well.
    In order to move the body, you will need to loosen the 2 bolts on the front of the body and push the body to it's new location. It's probably stuck in it's position if it hasn't been moved in a while, so get out your pursuader and give it a couple whacks to jar it loose. (soft BFH preferred)
    It's an option to have quill position confirmation on the machine, but if you do, you should have some indicator lights on the front panel and a rod next to the quill that moves with it. You will have to adjust the rod "dogs" to get the limit switch to come on when it is in the correct position. They are under the plate on the top of the tailstock body.
    Best regards,
    Mar 2009
    1982
    there is a posibillity to control tailstock interlock also. This ir good when You need to prepare face of workpiece before supporting it by tailstock.
    N0010 (program start)
    N0060 M157 (tailstock interlock release)
    N0070
    N0080 (face preparation)
    N0090 M56 (tailstock quill advance)
    N0100 M156 (tailstock interlock on)
    N0110 (work with tailstock)
    I'm not 100% sure about M code. Check the list of M codes, please.
  1. M Code for Tailstock?
    By Crashmaster in forum G-Code Programing
    Last Post: 10-23-2022, 07:41 PM
  2. Centerdrilling for tailstock
    By penjas14 in forum Uncategorised MetalWorking Machines
    Last Post: 01-14-2009, 03:49 PM
  3. sl-30 tailstock
    By travis1 in forum Haas Lathes
    Last Post: 11-04-2008, 05:32 PM
  4. Tailstock M-Code?
    By gcrudgington in forum Daewoo/Doosan
    Last Post: 09-28-2007, 02:42 PM
  5. TL-2 tailstock
    By rbest27 in forum Haas Mills
    Last Post: 11-11-2006, 12:20 AM
